Motor Running Rich After Valve adjustment http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=29405 |
Author: | Bubby83 [ Tue May 22, 2012 7:35 pm ] |
Post subject: | Motor Running Rich After Valve adjustment |
I just set my valves on my BD 4500 the other day. they were way out. .008 on the intake and .015 on the exhaust. I set them all to .006. Since the adjustment I have notice that my motor seams to be running rich. Plugs are black, and if I run for a while, shut it down, then try and start it a couple minutes later, it is hard to start. Is this a common thing? how would I go about adjusting my carb to lean it out a bit? |
Author: | dguidry [ Tue May 22, 2012 8:17 pm ] |
Post subject: | Re: Motor Running Rich After Valve adjustment |
Does TDC mean anything to you? |
Author: | richard nagon [ Tue May 22, 2012 8:41 pm ] |
does burnt fingers mean anything to u. dguidry ![]() |
Author: | dguidry [ Tue May 22, 2012 8:47 pm ] |
Author: | Bubby83 [ Wed May 23, 2012 11:19 am ] |
Author: | dguidry [ Wed May 23, 2012 12:33 pm ] |
Author: | cb5331 [ Wed May 23, 2012 1:15 pm ] |
What was wrong before you "fixed" it? |
Author: | Woodiebuster [ Wed May 23, 2012 2:26 pm ] |
running to lean ![]() |
Author: | Bubby83 [ Wed May 23, 2012 5:08 pm ] |
Author: | cb5331 [ Wed May 23, 2012 5:17 pm ] |
Yeah, I saw where you posted that but the motor wasn't running like shit before you messed with it, right? What else has changed? |
Author: | Bubby83 [ Wed May 23, 2012 6:35 pm ] |
no more valve clatter..... |
Author: | cj [ Wed May 23, 2012 8:16 pm ] |
if you set your valve lash to exact specs. i would think that your rich problem was already present.you might be just noticing it after the fact. i would rejet your carb install new plugs and run a test on it. |
Author: | cb5331 [ Wed May 23, 2012 8:26 pm ] |
Author: | cb5331 [ Wed May 23, 2012 8:27 pm ] |
Maybe your prop too. That could cause it. ![]() |
Author: | cj [ Wed May 23, 2012 8:32 pm ] |
i'am i missing something here. or are u in one of your moods ![]() |
Author: | cb5331 [ Wed May 23, 2012 8:38 pm ] |
No problem other than a little clatter...set valves...PROBLEMS... Only one thing changed on this motor to make it start running like shit...I'd start with rechecking the only thing that changed... Think simple, stupid! ![]() |
