It is currently Tue Jul 15, 2025 12:42 am
[ 7 posts ] |
GSUrugger
 slight rpm loss
I got my original problem fixed (sputtering, only running around 3500 rpms can be seen herehttp://www.mudmotortalk.com/mmt_v2/ ... =3&t=28475 ). spark plugs appeared to be the culprit, and it ran better upon taking it out. problem now is a slight (appx 300) rpm loss. could only run around 4150-4250, normally am running somewhere around 4400-4500. I am going to check the lash tonight or tomorrow to double check i set it correctly. could the lash being set too tight or loose cause this rpm loss?
_________________ Gator Trax 1644 HD pushed by a screamin' MB Mini 35
Thu May 17, 2012 8:26 am |
MaXXis85
 Re: slight rpm loss
Yep check valve lash. Valves too tight can keep the valve Open off the seat, and too loose wont open them far enough...
Thu May 17, 2012 9:58 am |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
 Re: slight rpm loss
make sure your head gaskets aren't leaking as well, Joel. That could cause a slight rpm loss if the leak is minimal.
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Thu May 17, 2012 10:10 am |
GSUrugger
 Re: slight rpm loss
have a hunch it's the valves. Jim i checked when i was home for lunch and no obvious leaks. those gaskets got a good bit of attention when we reinstalled the heads.
Thu May 17, 2012 10:43 am |
GSUrugger
 Re: slight rpm loss
got in the valves last night. one of the exhaust valves was way loose. hopefully that'll curtail my problem.
Thu May 24, 2012 6:06 am |
mizzippi jb
 Re: slight rpm loss
i hear ya! My valves were rattling pretty good after a few hrs. with the new heads. So bad the motor would sputter some after the switch was turned off. Just reset em after the ride last weekend. You finished with rugby season? Ready to put a ride or 2 together?
Thu May 24, 2012 6:44 am |
GSUrugger
 Re: slight rpm loss
Thu May 24, 2012 7:02 am |
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 73 guests |
