prodrive reverse question
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=29421
Author:  green head [ Wed May 23, 2012 10:37 am ]
Post subject:  prodrive reverse question
i just got my first mud rig i bought the hull and just put my prodrive on it today
my question is how far should i be able to trim down the motor before the cavitation plate hits the hull
Author:  CLICKSTER [ Wed May 23, 2012 10:41 am ]
Post subject:  Re: prodrive reverse question
stick your head back there and watch it. or listen for the clunk!
Author:  WestEndAngler [ Wed May 23, 2012 10:47 am ]
Don't they make a wedge or block thing that prevents the motor from trimming too far down while in reverse? I've seen a few rigs with them.
Author:  Woodiebuster [ Wed May 23, 2012 10:50 am ]
are they matching transom hieghts?
You dont have a short trans motor on a TT boat do you?
Author:  OwenDickeson [ Wed May 23, 2012 10:57 am ]
The cav plate hits the boat, its not a short transom motor on a tall transom boat kind of thing.
WEA- There is no such block to my knowledge, there is a block on winch trims to keep the motor from popping up, and on the hydr trim there is a lever that locks the trim in so the motor wont kick up.
Guys if you dont know shit about PDs, then dont try to answer questions that people have about them.
To the OP, you've just got to learn to not trim the motor too far down when in reverse. Part of the design is to be able to create lift at the transom with the motor, so keep it trimmed up pretty good when in reverse. If you have it trimmed down too far, and have to the motor turned just the right way, you can hit your boat with the prop.
Author:  swampbilly [ Wed May 23, 2012 10:59 am ]
Trim it down as far as u can and still b able to turn ur motor. If u go to far the cav plate will touch the transom and u won't b able to work the motor back and forth. Mine has an 1/8 inch plate welded to the transom in case it hits. If it does I just trim up till I can turn the motor again.
Author:  OwenDickeson [ Wed May 23, 2012 11:05 am ]
To answer your question about how far.
Author:  Robn1020 [ Wed May 23, 2012 11:36 am ]
Author:  Will [ Wed May 23, 2012 1:00 pm ]
Author:  OwenDickeson [ Wed May 23, 2012 1:19 pm ]
You've got to be f'ing with me.
Author:  cb5331 [ Wed May 23, 2012 1:28 pm ]
It is not that fucking complicated!!!!
Author:  Robn1020 [ Wed May 23, 2012 1:46 pm ]
Author:  Podcast [ Wed May 23, 2012 1:50 pm ]
Author:  green head [ Wed May 23, 2012 2:04 pm ]
its a tt motor on a tt boat i just wanted to make sure it was normal like i said its my first rig
thanks for all the help i appreciate it
Author:  coastal [ Wed May 23, 2012 2:33 pm ]
Trim it down just before it hits the boat. Then take a center punch and mark the transom bracket and motor bracket with the punch so you have something to look at every time you put it in reverse and never trim down below the marks.
Author:  JIMMY W [ Wed May 23, 2012 2:38 pm ]
:lol:
Author:  coastal [ Wed May 23, 2012 2:46 pm ]
Author:  The Shafer [ Wed May 23, 2012 2:50 pm ]
nice custom hyrdo lines cope....
Author:  coastal [ Wed May 23, 2012 2:56 pm ]
Original ones were junk. ;)
Author:  The Shafer [ Wed May 23, 2012 2:57 pm ]
will those increase my speeds any?
Author:  cb5331 [ Wed May 23, 2012 3:00 pm ]
Post subject:  Re: Re: prodrive reverse question
Author:  tchauvin [ Wed May 23, 2012 3:01 pm ]
One day, i seen a gator tail going 33mph in REVERSE....
I thought...chaaawwww...he must have that new "reverse plate"... :lol: :lol: :lol:
Author:  Will [ Thu May 24, 2012 5:52 am ]
