It is currently Mon Jul 14, 2025 11:54 pm
[ 4 posts ] |
greenheadman1
 No fire!!
Motor was running fine, had a short in the clutch wire which was killing the motor, fixed that run for about another 30 min no problems, pulled the boat up on a sandbar for about 2 hours to ski with some friends and get ready to leave and the motor will not crank. It's getting fuel for sure. I've checked everything i can think of including low oil pressure switch, kill switch, wiring etc... I'm not getting any fire to either plug. I run fresh water only, it's an 06 31hp with carb, heads & exhaust with electric trim. Any ideas?? I'm about to pull my hair out!!
Sun May 27, 2012 11:25 am |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
 Re: No fire!!
Kill lanyard
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Sun May 27, 2012 11:33 am |
marsh chicken
 Re: No fire!!
If you checked all those things...it could be your coils have gone bad. I just had to replace mine after they got all corroded, and the motor died on me. Def a possibility if your not getting any spark
Sun May 27, 2012 11:39 am |
greenheadman1
 No fire!!
Never mind, fixed it! The low oil pressure sensor wire had a bad place in it where it is zip tied to the intake manifold and was shorting the system out.
Sun May 27, 2012 1:47 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 92 guests |
