It is currently Mon Jul 14, 2025 8:07 pm
Reply to topic  [ 6 posts ]
 23hp surge up & down
Post 23hp surge up & down
got a brand new 23 van,,,at full throttle it surges up and down,,, i havent hooked up tinny tac yet so im not sure what the rmps are ,, but im relativly sure its going to be in the 3600 nieghborhood,,the linkage works back in forth on its own at the carb,, is this the governer if so how do u fix,,,,
off the streets and on the creeks
15/42 crawdad 23 swomp
Sat May 26, 2012 12:12 pm
Post Re: 23hp surge up & down
That is the gov. You need to bypass it. Look at the BPS or SETX performance sites. I believe they have a kit.
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Sat May 26, 2012 7:13 pm
Thats running wide open in or out of the water?, should go away when under a load or the idle spring on the gov. doesnt have enough tension. The idle spring will change your overall rpm so I wouldnt play with it till the tach's installed.
Sat May 26, 2012 7:43 pm
Profile YIM
out of water
Sat May 26, 2012 7:46 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat May 26, 2012 8:26 pm
willdo
Sun May 27, 2012 3:05 pm
Users browsing this forum: No registered users and 131 guests
