It is currently Mon Jul 14, 2025 3:38 pm
Reply to topic  [ 31 posts ]
 100LL aviation fuel
Post 100LL aviation fuel
I searched to see if anyone else was running 100LL avgas in their motors, and all I came up with was a brief mention of it in the fuel 101 post. "Premium" gas in Alaska is 90 octane... I was having a nightmare of a time tuning my motor with 90, it seemed to always be detonating, and it would "diesel" when I shut it off. I tried using bigger jets, then it seemed like I went from a super hot lean running motor to fowled up black sooty plugs with nothing good in the middle. I mixed 50/50 avgas and 90 octane and the detonating went away, my motor isnt running nearly as hot anymore (I finally got that nice paper bag color spark plugs), and the motor does not "diesel" anymore when I shut it off.
Anyone else run avgas, or have the same problems? It would be nice to solve my issues without having to buy gas at the airport.
Fri May 25, 2012 10:49 pm
Post Re: 100LL aviation fuel
Fri May 25, 2012 11:23 pm
I run 50/50 avgas/93octane. If I use a little fuel , like a gallon or two, I top off with 93 and add oct booster. My avgas here is 6.50gal...
Sat May 26, 2012 7:13 am
Av gas is a great alternative to running race gas, here in Wi it's only about $1.50 more then premium pump gas depending on where you buy it. vp race fuel $12-14. I ran the av gas in my turboed mountain sled and it works great.
Sat May 26, 2012 8:23 am
Its 5.80/gal here.. and 90 octane is 4.80/gal.... good thing my motor doesnt burn up a whole bunch of fuel... maybe 4 gal each time I go out. I wonder if the lead content in the fuel will gum anything up.
Sat May 26, 2012 12:43 pm
Decarbonizing the motor?
Sat May 26, 2012 3:03 pm
Where in lafayette can i find that avafuel i been using vp c12
Sat May 26, 2012 6:59 pm
I run premium and add 108 octane fuel.additive....only problem is it sputters and kicks a little when I turn it off.
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Sun May 27, 2012 8:04 am
Where you get your additive, Jefe?
And avgas = aviation gas. My local airport that is 2 miles away sells it 24/7!
Sun May 27, 2012 8:54 am
Sun May 27, 2012 10:40 am
Big bottle at auto zone for about 9 bucks.
Sun May 27, 2012 12:41 pm
Even Wal-Mart has 104 Octane Boost
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun May 27, 2012 12:44 pm
I been buying stuff, but it didn't say what octane boost it was I didn't think.
I was running the river yesterday with a FULL load and I noticed it started the pinging once it got good and warmed up(15 min @3800) Guess I'll be running straight avgas from now on...
Mon May 28, 2012 9:43 am
I gave up mud motors
Mon May 28, 2012 10:31 am
I got tanks full of aviation full out here in the plant and can't even use the shit, nor gas, nor diesel, i mean we make the shit and i have to pay for it, crazy how that works
Mon May 28, 2012 2:12 pm
Mon May 28, 2012 5:10 pm
Jw.. What exactly is the point in running this fuel? Av fuel of just booster. I always thought that it really didint do much without having timing adjusted just for that fuel?
1850 Uncle J
Delta Performance level 4 GTR
Tue May 29, 2012 1:25 am
I could be very wrong, but my understanding is that detonation can be caused by several issues: timing too far advanced, "lean" fuel burn, "lugging" the engine, poor quality fuel, overheating, poor quality oil,. If the timing is too far advanced, if a blocked fuel passage or partially blocked passage in the carb, running an incorrect size prop so the engine doesn't turn the upper limits of the rpm range,fuel that doesn't have proper octane, marginal water cooling, oil with poor lubricating properties. All of these individually or in combination with each other may cause detonation, pre-ignition and eventually severe internal damage.
Tue May 29, 2012 7:50 am
Tue May 29, 2012 7:56 am
The higher compression engines need higher octane level fuels. If you're runnin a stock motor, or have compression of ~150-180, you should be fine with supreme pump gas.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue May 29, 2012 8:04 am
My motor guy just suggested I use a cooler plug. I'll keep y'all posted.
Tue May 29, 2012 8:23 am
No matter what mods you have, the stock Champion plugs should be good.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue May 29, 2012 8:40 am
I've had good luck with the autolite 3923's. They are a slightly cooler plug.
Tue May 29, 2012 9:53 am
Thanks man! I'll check em out!
Tue May 29, 2012 9:58 am
I've always thought of octane boosters as penis enlargement pills... they both cost alot and neither one of them actually does anything.
Tue May 29, 2012 2:20 pm
Post Re: Re: 100LL aviation fuel
Tue May 29, 2012 2:42 pm
People think higher octane fuel = more power......
Tue May 29, 2012 3:43 pm
Tue May 29, 2012 3:55 pm
I have a 36 pro-drive bout 4 years old. Normally runs great but it looses power just like a fuel vent closed when i'm running with a load and wide open for about ten minutes or more. it's been doing this forever. Couple year's back i switch't from 87 octane too 92 octane that seemed to help. Now the problen is returning. Do i need to mix 92 oct and 100 oct?
18x48 pro-drive with a 36 pro-drive bad 2 da bone!!
Tue May 29, 2012 5:32 pm
sounds like you need a fuel pump.
Tue May 29, 2012 7:02 pm
Tue May 29, 2012 11:09 pm
Users browsing this forum: No registered users and 104 guests
