No fire!! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=29504 |
Author: | greenheadman1 [ Sun May 27, 2012 11:25 am ] |
Post subject: | No fire!! |
Motor was running fine, had a short in the clutch wire which was killing the motor, fixed that run for about another 30 min no problems, pulled the boat up on a sandbar for about 2 hours to ski with some friends and get ready to leave and the motor will not crank. It's getting fuel for sure. I've checked everything i can think of including low oil pressure switch, kill switch, wiring etc... I'm not getting any fire to either plug. I run fresh water only, it's an 06 31hp with carb, heads & exhaust with electric trim. Any ideas?? I'm about to pull my hair out!! |
Author: | dguidry [ Sun May 27, 2012 11:33 am ] |
Post subject: | Re: No fire!! |
Kill lanyard |
Author: | marsh chicken [ Sun May 27, 2012 11:39 am ] |
If you checked all those things...it could be your coils have gone bad. I just had to replace mine after they got all corroded, and the motor died on me. Def a possibility if your not getting any spark |
Author: | greenheadman1 [ Sun May 27, 2012 1:47 pm ] |
Never mind, fixed it! The low oil pressure sensor wire had a bad place in it where it is zip tied to the intake manifold and was shorting the system out. |
