23 Vanguard Kill Switch
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=29575
Author:  sftull [ Wed May 30, 2012 8:45 am ]
Post subject:  23 Vanguard Kill Switch
I just purchased a brand new 23vanguard and I need to know which wire to connect my kill switch to. I know how to wire the rest of the switch, just need to know which wire to hook it to. I don't want to fry this engine.. Below is a pic of the side of the engine. If you can't tell me which wire, is there a way to figure it out with a meter?
p.s. I used the search feature first and didn't find what I was looking for, so don't be a dick.
Thanks
Author:  hunt682 [ Wed May 30, 2012 11:26 am ]
If you can wait till tomorrow I'll let you know when I get home and can look.
Sent via telegraph
Author:  BoatDR [ Wed May 30, 2012 11:52 am ]
Post subject:  Re: 23 Vanguard Kill Switch
Behind the fuel filter there is a stud that the black wire hooks to. Put a ring terminal on the wire from the kill switch and attach it to that stud.
Author:  sftull [ Wed May 30, 2012 12:57 pm ]
Author:  BoatDR [ Wed May 30, 2012 1:03 pm ]
The bolt below the filter (that the brown wire in the pic is hooked to) is a ground.
The stud above that (it is behind the filter in that pic) is where the wire from the coils is attached to.
Author:  sftull [ Wed May 30, 2012 1:18 pm ]
BoatDR thank you for the explanation....I am new to these engines and don't want to mess anything up.
Just so i'm clear, I have one wire attached to the stud that the brown wire is attached to.(It has a yellow boot around the crimp fitting.) It runs to my switch and from my switch, I connect the other wire (its hanging there in the picture) to the stud behind the filter.
Author:  BoatDR [ Wed May 30, 2012 1:24 pm ]
Author:  sftull [ Wed May 30, 2012 2:25 pm ]
I had the kill switch hooked up and working on my other motor (16hp clone) so when I change motors, I left everything in place. I have 4 terminals on the back of the switch.....do I need to change them with this new engine?
Author:  BoatDR [ Wed May 30, 2012 2:36 pm ]
nope, same 2 terminals.
Author:  sftull [ Wed May 30, 2012 2:38 pm ]
Thank you again for your help!!
