It is currently Wed Sep 17, 2025 10:23 am
[ 4 posts ] |
Sparkleberry Runner
 Prodrive Hydro Trim
Anyone know what kind of fluid does it take and how i can drain it? thanks
Sat Jul 04, 2009 1:08 pm |
duckhunter888
Joined: Wed Jan 14, 2009 10:44 pm Posts: 828 Location: North Texas
 Re: Prodrive Hydro Trim
Any dextron automatic transmission fluid, non-foaming. PD uses Havoline MD-3. Not sure about draining it.
_________________ Crisis defines character
Sat Jul 04, 2009 2:16 pm |
Gatorpoint
Joined: Tue Jan 13, 2009 8:09 pm Posts: 1175 Location: A slough behind you, TEXAS
Trim your engine all the way down and disconnect the ram from the cross member. Retract the ram all the way into the cylinder. This will minimize how much fluid will be in your lines. Break them loose. You wont have much run out at all. Remove pump, motor,and reservior from bracket. (You may have to remove the whole assemble from your motor mounting bracket.) You can unscrew the reservior and drain. If you try and drain it in place, you are probably gonna make a mess.
_________________ 1854 Brotha Breaux Bateau pullin' a 35 GT arrrrahhh! Willett Welding custom boat trailer
Sat Jul 04, 2009 2:52 pm |
Sparkleberry Runner
Thanks guys for the info
Sat Jul 04, 2009 5:09 pm |
[ 4 posts ] |
