| Prodrive Hydraulic Reverse Gear http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=29771 |
| Author: | Will [ Fri Jun 08, 2012 6:27 am ] |
| Post subject: | Prodrive Hydraulic Reverse Gear |
It appears when you have the hydraulic reverse, the lower unit soley relies on the reverse gear to hold it in place. I have already had to "jump" a tooth to get the play out of the lower unit from the last 2 teeth catching abuse. I was wondering if I put in a reverse pin if it would stop this from happening. I know it will add a step to the reverse process and whats the point of hydraulic reverse if you have to pull a pin but this seems to be an issue. Opinions....? |
| Author: | OwenDickeson [ Fri Jun 08, 2012 7:49 am ] |
Call Peck. |
| Author: | mizzippi jb [ Fri Jun 08, 2012 8:00 am ] |
| Post subject: | Re: Prodrive Hydraulic Reverse Gear |
Or autogateman |
| Author: | OwenDickeson [ Fri Jun 08, 2012 9:01 am ] |
Why?? |
| Author: | The Shafer [ Fri Jun 08, 2012 9:15 am ] |
| Author: | Will [ Fri Jun 08, 2012 10:29 am ] |
Are you saying to call them for a pin? If so, that's fine but has anyone else had this issue or do you think this would help protect the reverse gear? |
| Author: | The Shafer [ Fri Jun 08, 2012 11:04 am ] |
I'm saying (and I also believe Owen is saying) is to call Peck and tell him the problem you are having with the gears. He will tell you the best solution to your problem. |
| Author: | Will [ Fri Jun 08, 2012 12:17 pm ] |
I just looked and the pin wont help. Im waiting to hear back from kp. |
| Author: | OwenDickeson [ Fri Jun 08, 2012 1:21 pm ] |
I'm saying call them because something is not right, no need to ****** rig it. |
