kemis
Joined: Fri Apr 29, 2011 1:33 pm Posts: 8 Location: Sweden
 Dyno test BPS 5500 engine, 54hp
Have done a dyno test on a BPS 5500 engine now.
A base 45 Mag Engine give about 45 hp so the Iron Mountain Heads give about 8-9 hp more in our test. The 5500 engine have: - Iron Mountain Heads - BPS Oversize Stainless Valves - Mikuni 42mm Carb - BPS Black Death Intake - K&N air cleaner - BPS Cam - BPS Stroker Rod & Pistons - Roller Rockers We have tested with exhaust system: - BPS "Q" Stainless Muffler - Straight flow - Special catalytic exhaust system for low emissions called Preburn Catalytic System, a pend prototype from Sweden. Not much difference between the system, about 1 hp. On the first test we have messure 53-54Hp at 4800-5200Rpm and torque on 95Nm at 3000-3500Rpm. We will have a complete report next week from a longer test. We do not use any RMP limit in the test bench so 5200 is maybe little high to run the engine on in long term. But as you can see the best torque is at 3000-3500Rpm. But do not run this engine without a rev limiter in real life! In this test we can control the engine good and know the risk. But it revs much more than 5200 rpm and this can damage the engine, or lets say its damage the engine! The engine have a very fast response and goes very nice! Have tested allot of parts from other manufacture to but so far BPS have the best performance parts I have found together with good support.
Fri Jun 08, 2012 10:32 am |
woodysqueal23
 Re: Dyno test BPS 5500 engine, 54hp
Nice , so you say the bps Q flows pretty good? I've heard mixed reviews on them not flowing as good as some of the others. Im looking to quiet my rig down and thought that would be the ticket. Your thoughts?
Fri Jun 08, 2012 10:59 am |
WestEndAngler
MMT Moderator
I am no motor expert...
What sort of HP/ Torque loss comes in when you add the belt, lower unit, prop & water you're riding in into the equation? I know this is a tough question to gauge, perhaps a percentage would be an appropriate answer?
I noticed the test was off the motors output shaft.
Fri Jun 08, 2012 11:37 am |
whytry85
Joined: Mon Nov 01, 2010 7:18 pm Posts: 276 Location: East Texas
you may take this with a grain of salt, But in automotive applications you usually lose between 10-15% through the drivetrain. i would think it would similar to these motors due to fact that you have the drag on the boat from the water, prop slip, etc......
_________________ 1748 prodrive 36 fpr w/ some bolt ons...
Fri Jun 08, 2012 1:11 pm |
BayouBuster
Joined: Sat Jun 25, 2011 8:33 am Posts: 1352 Location: Genoa AR
I would guess it could lose about 20 percent. Like an engine does in a car when you add a tranny and rear differential. --- I am here: http://tapatalk.com/map.php?b5bnng
Fri Jun 08, 2012 1:13 pm |
deadbird8
He's out of Sweden and using the motor for a hovercraft application, interesting.
Fri Jun 08, 2012 5:58 pm |
shallow water master
Joined: Tue Jun 16, 2009 8:27 pm Posts: 1803 Location: Belle Chasse La.
good info man keep posting
Fri Jun 08, 2012 7:16 pm |
autogateman
I just googled that dyno and that thing is $5k for the basic one!!
Fri Jun 08, 2012 7:50 pm |
redleg3316
Joined: Sat Nov 14, 2009 5:06 pm Posts: 414 Location: MS / were ever da rig floats
Awesome first post!
_________________ 1648 war eagle with a 50 Tohatsu
Fri Jun 08, 2012 9:30 pm |
Woodiebuster
I thought we had another DDM on our hands after that choppy English
Fri Jun 08, 2012 10:26 pm |
BoatDR
Thanks for the report Kemis. It is good to see other (independant) testers check to verify what the factory has done too.
Only piece of advice that I have is to get rid of that K&N air filter. We found that they were too restrictive for the 5500 motor. The new one that they use is made by Tau Ceti, and it is just a flame arrestor (just a metal screen, no filter paper at all) with the pre filter outer ware to keep moisture out.
Sat Jun 09, 2012 9:34 am |
Will
Sat Jun 09, 2012 10:13 am |
BoatDR
Sat Jun 09, 2012 11:12 am |
Will
10-4, that makes since. Good clarification.
Sat Jun 09, 2012 11:16 am |
BoatDR
Here ya go Will, you should appreciate this one.
This came off of someones boat that insisted on using a K&N, and found one for a 350 chevy that happened to fit on the velocity stack. If you have a 42mm Mikuni you'll understand how big this acutally is, but if not take a look at the second pic for a comparison to a 2 liter bottle.
Sat Jun 09, 2012 11:41 am |
Will
I understand what you are saying and I have had motorcycles with smaller breathers producing more horse power, just curious why these need so much air. Less than 1000 cc's, how much is a chevy 350? 5,500 cc's I think...
Sat Jun 09, 2012 12:59 pm |
kemis
Much talking about the K&N filter. Was on the picture but on this picture below we use something else and this do not restrict the air flow much and give little numbers to! Coming back with this as soon I have little time over and get them. But I should see if we can do a test to se how much this K&N filer really restrict the engine. In our application we do not use this K&N filter. We have a much larger filter on the side. There is no space for a larger filter on the carburetor as someone explain a real filter is big! If you use a larger K&N filter the exhaust is in the way or it get to o hot. We use a silicone and aluminum tube to the larger air filter. The interesting hp for me is on the outgoing shaft. How much hp you get in the end of an application is not interesting because the application is different. When you buy a new B&S you have a number on hp and this number is from the shaft. You need a number so you can compare the engines. So measure on the last end is not interesting in this case because you cannot compare the engines then. But I agree that you have a loss on 5-20% in the transmission. And sorry for my "choppy English" but my Swedish is bad too so my English is not better.
Sat Jun 09, 2012 4:19 pm |
woodysqueal23
50hptiller, i am curious about that too. I want to try the bps q but heard it doesn't flow well. After reading this, im wondering how much it matters. Im only stage 1so maybe it'll be ok for me. Not sure.
Sat Jun 09, 2012 7:57 pm |
Woodiebuster
Welcome to the forum!
Hope you stay around!
Sat Jun 09, 2012 8:20 pm |
OwenDickeson
Welcome to the forum Kemis, I have a really great friend from Sweden, I hope you stick around!
Sat Jun 09, 2012 8:36 pm |
PaleoHuntr
Joined: Mon Feb 21, 2011 5:21 pm Posts: 1800 Location: Idaho Falls, ID
^^ agreed! Great first and second posts, thank you!
_________________ 1976 16X48 Lowe powered by a 25hp MB LT and dino turds
Sat Jun 09, 2012 8:53 pm |
kemis
50hptiller explain the exhaust system very good in his post and much more! The word I chose "Straight flow" may not be the best one.
What we do is testing for a new catalytic exhaust. So the 3 different exhaust system we tested are: - BPS "Q" Stainless Muffler - Straight flow and in the end we have a muffler but no catalytic. - Special catalytic exhaust system for low emissions called Preburn Catalytic System, a pend prototype from Sweden.
The catalytic system we use need the pulses to preburn the emissions. No more white smoke and a wife that complain that you smell like shit!
The difference in hp between this 3 system seems to be small.
But the system we test you can compare with a system with the "Q" muffler in performance.
But for you mudpeople the "Q" Stainless Muffler, Twin Stainless Muffler or Single Crossover Stainless Muffler or something similar should be the choice. If you want lower sound the "Q" is probably the best choice and if performance is nr 1 the Crossover and Twin Stainless Muffler may be another one.
Maybe 50hptiller have the answer on this or someone else that have test all 3 on the same engine can explain the difference in performance, sound aso.
I only want to give a indication on how much you can expect from a 5500 engine.
Sun Jun 10, 2012 4:55 am |
kemis
Yes I use 1,5" to 2" and a 15 degrees merge coll on all new exhaust I have done. This should give little better performance they told me. But have 1,5 and 2" on the test exhaust to but a higher angel and not a real merge coll.
But you talking about a 42" long pipe. Is this after the merge to 2" pipe?
We have about 42" pipe after the catalytic today. And about 20" befor. Need a absorber before the cataltic for the vibrations.
Sun Jun 10, 2012 3:33 pm |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
Kemis: You might be familiar with SKanska, one of the top 5 construction companies in the world organized and headquartered in Sweden. My daughter works as a civil engineer for them in New York. These are some of her projects:
Major projects
Major projects in the United States include the New Meadowlands Stadium (MetLife Stadium, home to the Giants and the Jets NFL franchises), completed in 2010.[13] Skanska is also the construction manager for Madison Square Garden's renovation project, due to be completed in 2012.[14] Skanska has also won the Alaskan Way Viaduct project in Washington: the project worth SEK840 million ($115 million) involves the construction of a new 1.3 kilometer viaduct on the southern section of the Alaskan Way on the State Route 99 bypass in downtown Seattle and will be completed in 2013. [15]
Another continuing major project is the renovation and addition to the United Nations building, due to be completed in 2014.[16]
Other continuing major projects include the restoration of the World Trade Center ground zero site including the removal of debris, the reconstruction of the PATH and New York City Subway and the creation of a World Trade Center Transportation Hub, due to be completed in 2014.[17] Skanska is also a member of consortium responsible for the Second Avenue Subway tunneling project, due to be completed in 2016.[18]
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Mon Jun 11, 2012 1:04 pm |
oncall
Joined: Mon May 10, 2010 1:46 pm Posts: 1180 Location: Georgia
_________________ 1854 Brother pulling a 36 PD viewtopic.php?f=5&t=12825 Brooks: "Tries masterbation and thank happy thots ...... purt near pulled mines off when I quit 'em ....."
Mon Jun 11, 2012 2:31 pm |
cash
Joined: Tue Jan 13, 2009 7:49 pm Posts: 352 Location: Ponchatoula, La
_________________ 1854 Gatortail CC . 35 GTR Stage 2
Mon Jun 11, 2012 3:19 pm |
dguidry
Sorry, I was only trying to make him feel welcomed. Carry on.
Mon Jun 11, 2012 4:13 pm |
POKER1
Mon Jun 11, 2012 5:52 pm |
kemis
The talk about the K&N filter that we use not have enough air flow to support the air to the engine is "almost" wrong. We have now measure up the difference between a K&N filter and a free flow with an Air Flow Meter and the difference is only a few %. That is not bad for a air filter that always have a small resistance. So the rumor that the filter do not give enough air is wrong.
But this is with a new filter!
The conditions can fast changes if the filter starting to get dirty. The marginal may be much smaller on this filter than others like a Tau Ceti air filter or larger filter.
But in the dyno test the K&N filter make no big difference.
But always use a clean filter and an extra micro cover prefilter for easy cleaning and protection. In our case we have water and snow that this micro cover prefilter stop coming in to the air filter and it is allot of snow and water we talking about! See picture of powder snow driving below. This snow cause no problem for the engine when use a extra micro cover prefilter.
Tue Jun 12, 2012 1:45 am |
txmudcutter
Joined: Mon Jan 30, 2012 9:08 am Posts: 2307 Location: Nederland, TX (SETX)
Good info kemis ...kool pic too
Tue Jun 12, 2012 6:37 am |
deadbird8
Wed Jun 13, 2012 5:41 pm |
postalpaul
Joined: Sun Nov 01, 2009 6:25 pm Posts: 1935 Location: Kaufman- TEXAS
Welcome!! And thank you for some very interesting info!!!
Wed Jun 13, 2012 8:22 pm |
kemis
No I only using 1 micro pre-filters. Same filter we use as you have for mudboats. The conditions are very similar as you have. The picture show drive in snow, but you can also drive on water, land and mud to. That's why this forum and this kind of product is so interesting for me. Have follow this forum for some times but it is first now I feel that I have something to chare.
Thu Jun 14, 2012 12:55 am |
GSUrugger
pretty cool information man. thanks!
_________________ Gator Trax 1644 HD pushed by a screamin' MB Mini 35
Thu Jun 14, 2012 6:06 am |
