35hp problem http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=29802 |
Page 1 of 2 |
Author: | jakecologne [ Sat Jun 09, 2012 6:47 pm ] |
Post subject: | 35hp problem |
I was running today around 4100-4150 rpms and the engine made a pop noise but didn't lose any power. I stopped to see and in neutral it seemed like it had a different kind of vibration. Any ideas? |
Author: | chaseh [ Sat Jun 09, 2012 6:56 pm ] |
Something broke |
Author: | jakecologne [ Sat Jun 09, 2012 7:02 pm ] |
I need a little bit more than that lol |
Author: | elebouef102 [ Sat Jun 09, 2012 7:05 pm ] |
Post subject: | Re: 35hp problem |
Well according to Robin, if it would be a GoDevil you could rule out the clutch and the transmission. ![]() |
Author: | jakecologne [ Sat Jun 09, 2012 7:30 pm ] |
I don't think it was a clutch or transmission. Nothing's slipped |
Author: | OwenDickeson [ Sat Jun 09, 2012 7:44 pm ] |
Author: | jakecologne [ Sat Jun 09, 2012 7:58 pm ] |
So back to what could be the problem.. |
Author: | richard nagon [ Sat Jun 09, 2012 8:08 pm ] |
Check ur valve train |
Author: | Team Camo [ Sat Jun 09, 2012 8:47 pm ] |
^^^ I was thinking push rods also |
Author: | OwenDickeson [ Sat Jun 09, 2012 9:10 pm ] |
You would lose power if you threw a pushrod though. Right? |
Author: | PaleoHuntr [ Sat Jun 09, 2012 9:13 pm ] |
Author: | Team Camo [ Sat Jun 09, 2012 9:17 pm ] |
^^^FAIL!!!^^^ Talkin push rods, not connecting rods ![]() Yeah, Owen, it would run like shit if he threw a push rod. I missed where he said he didn't lose power, was focused on the vibration. |
Author: | vertical_edge_800 [ Sat Jun 09, 2012 9:19 pm ] |
Could it have been a backfire and you just noticed more vibration because you were paying closer attention to it? |
Author: | PaleoHuntr [ Sat Jun 09, 2012 9:20 pm ] |
Author: | Woodiebuster [ Sat Jun 09, 2012 9:21 pm ] |
Author: | PaleoHuntr [ Sat Jun 09, 2012 9:27 pm ] |
Author: | Team Camo [ Sat Jun 09, 2012 9:27 pm ] |
Is the motor stock? |
Author: | take'emgator [ Sat Jun 09, 2012 11:12 pm ] |
Plugs may be in the beginning stage of fouling, pull them and check em. Last time mine popped i had to limp on one cylinder to a hunting hole, come to find out i blew a head gasket. Not your problem cause you would have noticed that. |
Author: | take'emgator [ Sat Jun 09, 2012 11:14 pm ] |
Author: | PaleoHuntr [ Sat Jun 09, 2012 11:30 pm ] |
You mean helpful like suggesting push rods without any power loss? Or maybe a blown head gasket that obviously isn't the problem either? I'll keep that in mind. |
Author: | jakecologne [ Sun Jun 10, 2012 2:09 am ] |
Just carb and exhaust |
Author: | Will [ Sun Jun 10, 2012 4:40 am ] |
Does it idle smooth still? If the idle is rough now, check your intake gasket. It could have ripped and now causing an air leak. |
Author: | bubba777 [ Sun Jun 10, 2012 7:00 am ] |
Might be the baffled in your muffler came loose better check fast them fuckirs will be on top your piston in no time |
Author: | Team Camo [ Sun Jun 10, 2012 7:50 am ] |
Do you have a rev box on it? Could've just been a hiccup in the box, causing a backfire like was mentioned earlier. |
Author: | jakecologne [ Sun Jun 10, 2012 9:34 am ] |
No rev limiter. And it does idle smooth. I think im gonna pull the valve covers off and take a look at the rocker arms |
Author: | jakecologne [ Sun Jun 10, 2012 9:48 am ] |
I have one roller rocker loose on each side...is that normal? |
Author: | cb5331 [ Sun Jun 10, 2012 9:49 am ] |
It depends where the pistons are at. Do you know how to set your valves? |
Author: | Will [ Sun Jun 10, 2012 9:52 am ] |
Yes they will be loose when that particular valve is in its seat. |
Author: | jakecologne [ Sun Jun 10, 2012 9:54 am ] |
No I don't know how to set them.. |
Author: | cb5331 [ Sun Jun 10, 2012 10:00 am ] |
No better time to learn! Take your time, make sure you get it right. http://www.youtube.com/watch?v=hGkn0jR9RJM |
Author: | med [ Sun Jun 10, 2012 11:24 am ] |
Another http://mudmotortalk.com/mmt_v2/viewtopi ... sh#p228779 |
Author: | jakecologne [ Wed Jun 13, 2012 1:44 pm ] |
Think I found my problem |
Author: | Will [ Wed Jun 13, 2012 1:46 pm ] |
yup If you took those three long bolt couplings out and left them out, would it hurt anything? |
Author: | jakecologne [ Wed Jun 13, 2012 1:48 pm ] |
How does that happen? Lol. Should I stress about finding the rod that broke off. Could this possibly be the reason I saw sparks as well? |
Author: | BoatDR [ Wed Jun 13, 2012 1:50 pm ] |
Author: | BoatDR [ Wed Jun 13, 2012 1:52 pm ] |
Author: | jakecologne [ Wed Jun 13, 2012 1:53 pm ] |
That metal screen was takin off when I had work done to the engine. Could this have possibly been the reason I saw the sparks out of the side? |
Author: | BoatDR [ Wed Jun 13, 2012 1:55 pm ] |
Author: | jakecologne [ Wed Jun 13, 2012 1:58 pm ] |
Yeah and it sparked for a little while then made a noise like it threw something around in there then it never sparked again. I have the fan cover with my oil cooler on it I just don't have that other little cover inside the fan cover |
Author: | deadbird8 [ Thu Jun 14, 2012 6:04 am ] |
Page 1 of 2 | All times are UTC - 6 hours |
