32hp and 36hp crankshaft question http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=30014 |
Author: | gatorkiller1967 [ Sat Jun 16, 2012 9:25 am ] |
Post subject: | 32hp and 36hp crankshaft question |
i know the bore is the same and the stroke is a little longer on the 36. But im guessing the difference is in the crankshaft? or are they the same crankshafts.. i have a 32 pd -needs a crank. can i use a 36 crank? |
Author: | autogateman [ Sat Jun 16, 2012 11:14 am ] |
The crank is what determines the stroke. |
Author: | gatorkiller1967 [ Sat Jun 16, 2012 11:24 am ] |
Post subject: | Re: 32hp and 36hp crankshaft question |
i figured that so a 36 crank wont work tks |
Author: | deadbird8 [ Sat Jun 16, 2012 8:58 pm ] |
You can use the 36 crank and change the connecting rods and carb to make it a 36. |
Author: | gatorkiller1967 [ Sun Jun 17, 2012 4:37 am ] |
i have a 36 crank. all i need is the rods then? will work with 32 block? |
Author: | take'emgator [ Sun Jun 17, 2012 5:24 am ] |
Yep |
Author: | gatorkiller1967 [ Sun Jun 17, 2012 5:30 am ] |
great! tks |
Author: | take'emgator [ Sun Jun 17, 2012 5:55 am ] |
32 and 36 same bore 32 has shorter stroke, couple mods and you can make it work |
Author: | gatorkiller1967 [ Sun Jun 17, 2012 7:16 am ] |
where can i get a cam? id like to add some hp |
Author: | take'emgator [ Sun Jun 17, 2012 9:45 am ] |
call cody at SetxPerformance and pick his brain, he can tell you different ways that you can set the cam up, so many differnet possibilities. There are several mechanics on here that can help you in that department |
