It is currently Wed Jul 16, 2025 7:50 am
Reply to topic  [ 9 posts ]
 RPMs FOR PRODRIVE 36
Post RPMs FOR PRODRIVE 36
hey guys just wondering what rpms yall would suggest me setting my pd 36 at.
im currently running 4000.
36pd 18'x46" sdb bonecrusher skiff
Tue Jun 19, 2012 10:26 am
If the tiller ain't pullin should be fine. If that's a stock motor ya sure are gettin good rpm. What kinda hull??
Tue Jun 19, 2012 11:15 am
Post Re: RPMs FOR PRODRIVE 36
If the motor is stock those are good rpms.
with tiller time, you will be able to "feel" when the motor is trimmed properly and is running its best.
WC 1848 Bateau w/ 36 PD FPR
Tue Jun 19, 2012 11:17 am
I turn 3950-4030 depending on load and placement of load.
1748 X-Series pushed by 36PD with MarshMellow Exhaust
Poule Deaux Crew
Tue Jun 19, 2012 11:24 am
By stating "set" the rpm, I assume you mean out of the water with no load. If that's the case, you should be at 4250. If you are turning 4000 in the water and have played with the trim and this is as fast as you can go then you are good, you can't "set" that other than knowing the trim hieght. Mine turned 4190 in the water on a 17x54 with a new prop and light load. I'm not sure of the difference in weight or design of your boat to compared to mine but it doesn't take much at all to loose a couple hundred rpm on the stock motor around the 4000 range.
Tue Jun 19, 2012 1:12 pm
will i think we talked to you yesterday and had it start turning right i appreciate it guys.
light load in water im pulling 4070
Tue Jun 19, 2012 1:33 pm
SDB HULL
Tue Jun 19, 2012 1:35 pm
I thought that was you. If both of you were in it and it turning 4070, I say that's about as good as you're going to get it. Did you have a gps to see what speed you were running?
Tue Jun 19, 2012 1:58 pm
just me in it i pulled 4100, i was keeping up with NFW before, now im geting hit with his rooster tail so it made a world of differenc. that gtr boat of his is quick son
Thu Jun 21, 2012 2:53 pm
Users browsing this forum: No registered users and 66 guests
