It is currently Wed Jul 16, 2025 3:11 pm
[ 4 posts ] |
OwenDickeson
 This little guy
What does this little guy do? It was blocked off with a rubber cap, but the cap has dry rotted and come off. Is there anyway to get rid of that fitting? It is in the way from getting the carb perfectly level on the motor because that fitting when it has the rubber cap on it hits the mounting bolt for the rubber carb flange.
Fri Jun 29, 2012 8:19 am |
Robn1020
Joined: Mon Feb 16, 2009 6:09 pm Posts: 4232 Location: Cypress, TX
 Re: This little guy
Isn't that the where the drain tube goes? Mine has a drain tube going thru to the top of my lower unit. On mine its facing down but I assume its on a vertical PD motor?
Fri Jun 29, 2012 8:37 am |
DMC
Joined: Sun Jan 25, 2009 7:23 pm Posts: 204 Location: Bayou House!
 Re: This little guy
I would assume its a vacuum port for some other application. You could pull the brass nipple out and plug it with small pipe plug, set screw, or just cut it off and silicone it. I left mine there and just siliconed it.
Fri Jun 29, 2012 9:02 am |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
 This little guy
It's a vaccum port. You can just plug it or remove it and seal hole.
Fri Jun 29, 2012 9:08 am |
[ 4 posts ] |
Users browsing this forum: No registered users and 104 guests |
