What would you all recommend to mod up my motor http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=30354 |
Author: | jjleffler [ Thu Jun 28, 2012 5:36 pm ] |
Post subject: | What would you all recommend to mod up my motor |
I have 31hp mudbuddy. I am not the most mechanically inclined so was wondering what were some of your opinions for mod my motor??????? |
Author: | BoatDR [ Thu Jun 28, 2012 5:47 pm ] |
Post subject: | Re: What would you all recommend to mod up my motor |
Not being mechanically inclinded, I'd start with carb and exhaust. Both are fairly simple bolt ons. |
Author: | Woodiebuster [ Thu Jun 28, 2012 6:11 pm ] |
I'd get a 35 carb, cam, heads, and exhaust. |
Author: | keystone light [ Thu Jun 28, 2012 7:35 pm ] |
Just curious what length outdrive is that Sent from my C771 using Tapatalk 2 |
Author: | jjleffler [ Thu Jun 28, 2012 8:09 pm ] |
Not sure where u measure tron but the back belt housing to the end of prop 42 from grease housing to b4 prop 35 and to end 39 |
Author: | Kja0792 [ Fri Jun 29, 2012 6:30 am ] |
Im building a 31 right now cody has.my heads doing carb exhaust cam and setx heads ill let u.know how t runs did 26 with 2 people light load before trying to get 30 - 32 with an ok.load |
Author: | duckmedic269 [ Fri Jun 29, 2012 8:41 am ] |
i started with single carb and crossover exhaust ...... what big difference so far . thats apretty good starting point and anyone can put these on themselves |
Author: | oncall [ Fri Jun 29, 2012 10:22 am ] |
Author: | Woodiebuster [ Fri Jun 29, 2012 10:29 am ] |
lefty loosey, righty tighty. A cam swap is the same concept as anything else ![]() Its not like you have to grind the cam out of a stone, just align the timing marks. ![]() |
Author: | cb5331 [ Fri Jun 29, 2012 10:31 am ] |
Woodie, you left out pistons and rods. If you're gonna do it, do it right. |
Author: | Woodiebuster [ Fri Jun 29, 2012 10:33 am ] |
your right, if he has the heads and the crankcase cover off, he might as well unbolt all of four bolts on the rod caps and replace that too. |
Author: | quackconsumer [ Fri Jun 29, 2012 10:40 am ] |
A good pair of mods to start with is a plutonium powered flux capacitor and a nitroglycerin fueled carb. |
Author: | Will [ Fri Jun 29, 2012 10:58 am ] |
If you know what a feeler gauge is and how to use it, go with a new carb with an accelerator pump, custom heads, and open exhaust. Adjusting the valves is really the only technical part and it's easy if you use the right technic. |
Author: | quackconsumer [ Fri Jun 29, 2012 11:31 am ] |
Author: | Will [ Fri Jun 29, 2012 11:46 am ] |
Author: | vertical_edge_800 [ Sat Jun 30, 2012 1:27 am ] |
replace the frame with a surface drive frame, which is about 3500$, and also cheaper than fully modding your motor ![]() But on a more serious note, carb, exhaust, and heads.. the heads arent too tricky you can youtube the crap out of how to adjust valves and figure it out. |
Author: | Richard in LA [ Sat Jun 30, 2012 2:39 am ] |
Author: | vertical_edge_800 [ Sat Jun 30, 2012 10:04 am ] |
looked like a longtail on my phone screen- I was so sure of it I had to pull a pic of it up on my computer! |
Author: | jjleffler [ Sun Jul 01, 2012 10:49 am ] |
Thanks everyone for all the comments and helpful info |
