It is currently Fri Jul 18, 2025 8:08 am
Reply to topic  [ 20 posts ]
 what exhaust for 36pd
Post what exhaust for 36pd
what exhaust should i look at getting for my 09 36 pd. it has a mikuni carb but stock exhaust and wanting to see what other people have and how they like it. im wanting to get the full potential out of my carb. thanks for any help
Sun Jul 01, 2012 6:13 pm
-gutted stock exhaust
-marshmellow
-bps Q
Sun Jul 01, 2012 6:36 pm
Post Re: what exhaust for 36pd
have you ever seen how say a motor cycle exhaust fits together ?
slip fit right ? it allows for expansion and contraction of the two different maiting sufaces
my vote is the marshmellow
been running one with no problems no crack at flanges like some of the others
Tue Jul 03, 2012 4:56 pm
If u want the most out your motor, crossover.
I have an EVT now because the crossover wouldn't stay together, but the crossover had a noticeable throttle response difference. I like the EVT, not too loud and much better than stock.
Not sure about MM, never had one.
18'x54"CC Hanko/ 36PD
Wed Jul 04, 2012 8:32 am
I just put a gutted stock stainless on mine. I'll give ya my thoughts in a bit
1850 & 36pd
Wed Jul 04, 2012 8:38 am
I have a MM and like it.
Wed Jul 04, 2012 11:51 am
Gutted exhaust sounds pretty bitchin'. Not too loud but throaty. Very happy with it.
1850 & 36pd
Wed Jul 04, 2012 3:22 pm
How do u gut a stock mufflers
Can someone please explain
Fred the Welder
Building them one at a time
Wed Jul 04, 2012 7:16 pm
I used a hacksaw and cut the ends off and then used various tools to remove the baffles. Then had the end caps welded welded back on.
Before
After
1850 & 36pd
Wed Jul 04, 2012 9:28 pm
Cool how will it affect the proformance of the motor
Fred the Welder
Thu Jul 05, 2012 6:43 am
It'll be able to breathe now
1850 & 36pd
Thu Jul 05, 2012 8:58 am
B. MacDonald
Thu Jul 05, 2012 2:01 pm
Post Re: Re: what exhaust for 36pd
Thu Jul 05, 2012 2:04 pm
Sounds simple enough to do is there any down fall to this mod if that's all I wanted to do to my motor
Fred the Welder
Thu Jul 05, 2012 7:12 pm
i lost some RPM when i went from a EVT to a gutted stock muffler...
and those "stainless" mufflers are not stainless... put a magnet on it!
I gave up mud motors
Thu Jul 05, 2012 7:17 pm
I still don't understand it's going to breath better dose that mean its going to run better what's advantage dose it have
Fred the Welder
Thu Jul 05, 2012 7:42 pm
Thu Jul 05, 2012 8:09 pm
I'm thinking about gutting my stock based on talking with you guys
My next Q how much loader is it I'm not looking to make my motor sound like a Harley
Any thoughts
Fred the Welder
Fri Jul 06, 2012 3:24 pm
It's a lil loud. Not bad tho. It'll be a while before I mod anything. Got a new prop coming and next will be hydro trim
1850 & 36pd
Fri Jul 06, 2012 4:19 pm
if you do the stock one use a flapper wheel to grind the crimp off the ends...
then use a tig to weld it back up... it holds up better than cutting the caps of and welding them back
Fri Jul 06, 2012 5:07 pm
Users browsing this forum: No registered users and 111 guests
