It is currently Wed Sep 17, 2025 4:17 am
[ 10 posts ] |
JD
 Costly mistake
The accelerator pump rod froze up in its guide hole on my 45 HSR.
In the process of getting it unstuck I broke the ear on the plastic pump lever that sits next to the cable lever. Those two parts were 12 bucks,thats not the problem. There is a brass bushing in the carb body that guides that rod, I had to drift it out to remove the rod. Those bushing are not available!!!! I got it back in ,I think I am OK. If it leaks it can't be replaced ,factory says I need a new carb.
I have been clearing the carb often with carb cleaner to keep salt build up down. I should have been oiling the rod. When you boys get older you will learn a dry hole is no fun, in this case it may have cost me a carb.
JD
Wed Jul 08, 2009 2:26 pm |
coondik
 Re: Costly mistake
just a thought... but did u ever consider another hobby?
Wed Jul 08, 2009 2:31 pm |
slambin
Joined: Mon Feb 16, 2009 10:21 pm Posts: 1262 Location: St. Francisville, LA
 Re: Costly mistake
_________________ 2060 CC 3/4 Gator-tail 1/4 Brother Breaux Boat /35GTR Cowboy thought- a thong on a woman is like a barbed wire fence. It protects the property but doesnt obstruct the view.
Wed Jul 08, 2009 2:38 pm |
JD
 Re: Costly mistake
Wed Jul 08, 2009 2:45 pm |
mcnemar1982
Joined: Mon Jan 19, 2009 4:03 pm Posts: 2216 Location: Walker, Louisiana
 Re: Costly mistake
_________________ Ideas not coupled with action never become bigger than the brain cells they occupied.
Owner DEEP SOUTH CUSTOM BOATS (225) 252-2700 Good boats ain't cheap, Cheap boats ain't good!
Wed Jul 08, 2009 2:47 pm |
coondik
 Re: Costly mistake
Wed Jul 08, 2009 2:49 pm |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
 Re: Costly mistake
Can you take a picture of what needs to be oiled? Is this something that everyone with a Mikuni should be doing or was this only causes by you cleaning it?
Wed Jul 08, 2009 4:29 pm |
JD
 Re: Costly mistake
Wed Jul 08, 2009 8:10 pm |
rg567
Joined: Wed Jan 14, 2009 8:35 am Posts: 21 Location: WI
 Re: Costly mistake
Having a machine shop make you a bushing may be cheaper than replacing the whole carb. Just a thought...
Thu Jul 09, 2009 5:15 am |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
 Re: Costly mistake
Breaking shit is always more fun, as long as it aint yours and you dont have to fix it.
_________________ BUCK OFAMA
Thu Jul 09, 2009 4:15 pm |
[ 10 posts ] |
