Costly mistake http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=3049 |
Author: | JD [ Wed Jul 08, 2009 2:26 pm ] |
Post subject: | Costly mistake |
The accelerator pump rod froze up in its guide hole on my 45 HSR. In the process of getting it unstuck I broke the ear on the plastic pump lever that sits next to the cable lever. Those two parts were 12 bucks,thats not the problem. There is a brass bushing in the carb body that guides that rod, I had to drift it out to remove the rod. Those bushing are not available!!!! I got it back in ,I think I am OK. If it leaks it can't be replaced ,factory says I need a new carb. I have been clearing the carb often with carb cleaner to keep salt build up down. I should have been oiling the rod. When you boys get older you will learn a dry hole is no fun, in this case it may have cost me a carb. JD |
Author: | coondik [ Wed Jul 08, 2009 2:31 pm ] |
Post subject: | Re: Costly mistake |
just a thought... but did u ever consider another hobby? ![]() |
Author: | slambin [ Wed Jul 08, 2009 2:38 pm ] |
Author: | JD [ Wed Jul 08, 2009 2:45 pm ] |
Author: | mcnemar1982 [ Wed Jul 08, 2009 2:47 pm ] |
Author: | coondik [ Wed Jul 08, 2009 2:49 pm ] |
Author: | Wilson [ Wed Jul 08, 2009 4:29 pm ] |
Can you take a picture of what needs to be oiled? Is this something that everyone with a Mikuni should be doing or was this only causes by you cleaning it? |
Author: | JD [ Wed Jul 08, 2009 8:10 pm ] |
Author: | rg567 [ Thu Jul 09, 2009 5:15 am ] |
Having a machine shop make you a bushing may be cheaper than replacing the whole carb. Just a thought... |
Author: | bjg [ Thu Jul 09, 2009 4:15 pm ] |
Breaking shit is always more fun, as long as it aint yours and you dont have to fix it. |
