fishfighter
 Honda GX 670 carb rebuild kit?
I'm looking for a rebuild kit for my Honda 24hp. Anybody know were is a good place to order it on line? I had hit 4 places in Baton Rouge with no luck.
Thanks.
Fri Jul 06, 2012 1:44 pm |
fishfighter
 Re: Honda GX 670 carb rebuild kit?
Nobody?
Sat Jul 07, 2012 5:13 am |
Richard in LA
Joined: Tue Sep 08, 2009 1:58 am Posts: 282 Location: Prairieville, LA
IIRC, its the same carb as on the 23 vanguard with just a different intake and flange for the air cleaner. When I had my old 24 GoDevil, they were out of "honda" parts when I needed some gaskets and such, and Charlie (the mechanic there) told me this as he handed me briggs packaged parts for it.
_________________ GTR, Waitin' on a DFOU hull
Sun Jul 08, 2012 11:52 am |
fishfighter
The carb is a Nikki. Dam part number brings up two different gaskets.
IIRC, what that stands for? Thanks
Sun Jul 08, 2012 12:09 pm |
cb5331
If I recall/read/remember correctly or something like that.
Sun Jul 08, 2012 12:17 pm |
fishfighter
Thanks! I'm just a bit slow. Old people. LOL
Sun Jul 08, 2012 12:25 pm |
Richard in LA
The 2 different gaskets you are finding is probably the intake gaskets and the float/bowl gasket. When I rebuilt mine, IIRC, I needed 2 or 3 of the "greenish" fiber/paper gaskets and one of the rubber(ish) spaghetti gaskets.
What is the part number off of your carb? I searched your previous posts, and I sawyou stated you own a GoDevil, did you try and go over there and get some? The gaskets are only a couple dollars.
Sun Jul 08, 2012 3:45 pm |
fishfighter
I found the right carburator. It is a pre 1997. My engine is a TAF Other numbers I was getting was gasket # 16010-ZN1-003 Which is not the right one. The one I need goes by the honda code of 6247696.
Got this info off Iboats.com and will call and order it tomorrow.
Thanks all that tryed to help.
Sun Jul 08, 2012 3:59 pm |
Richard in LA
according to the diagram on this page, both of those numbers you have listed are for the same part. Any reason you haven't called Go-Devil directly? http://www.boats.net/parts/detail/honda ... 1-003.html
Sun Jul 08, 2012 5:51 pm |
