It is currently Wed Jul 16, 2025 3:05 am
Reply to topic  [ 6 posts ]
 23 to 35 GTR
Post 23 to 35 GTR
Will a 35 fit on a GTR frame that originally came with a 23? Is the clutch transmission etc the same?
Tue Jul 10, 2012 12:36 am
Post Re: 23 to 35 GTR
The frame is the same for sure, depending on shaft size will determine if the clutch will fit, i'm gonna say its transferable. Make sure you get some shims cause that for sure is gonna be different, you wanna make sure that belt rides in the middle of that sprocket.
Tue Jul 10, 2012 3:30 am
Post 23 to 35 GTR
Anybody know if the shaft sizes are the same? Would be an expensive mistake if not
Tue Jul 10, 2012 6:54 am
Probably call gtr and they can tell you a lot quicker
Tue Jul 10, 2012 7:00 am
Everything will fit you will need to change the prop, bottom pulley, also the base plate that the motor sits on will be different for a 35. that is all you need
Calen's Engine Service
337-578-4434
Tue Jul 10, 2012 8:28 am
Post 23 to 35 GTR
Calen, what's a bottom gear and prop cost. Is the base plate different or are the bolt holes just different and I would have to drill new holes?
Tue Jul 10, 2012 10:30 am
Users browsing this forum: No registered users and 102 guests
