lilurb_03
 12' flat bottom
I have a flat bottom boat and I think I have a 5hp motor, and I say think because I can't find a model on it any where because it's a little rough. But the serial number starts GCACK and the internet says its a gx160. Anyway, I am relatively new to mud motors I was wondering if it is gonna be big enough for a long tail?
Tue Jul 10, 2012 5:34 pm |
PaleoHuntr
Joined: Mon Feb 21, 2011 5:21 pm Posts: 1800 Location: Idaho Falls, ID
 Re: 12' flat bottom
You can run a small LT on it, 6-9 hp or so, with no problem assuming you are on the smaller side. How wide is the bottom?
_________________ 1976 16X48 Lowe powered by a 25hp MB LT and dino turds
Tue Jul 10, 2012 5:45 pm |
lilurb_03
 Re: 12' flat bottom
3' maybe, that's just a guess with out measuring it. I just wanna make sure a 5hp is gonna be big enough for gear, 2 guys, and a dog.
Tue Jul 10, 2012 8:56 pm |
PaleoHuntr
 Re: 12' flat bottom
Depends on total weight of everything going into the boat. It sounds like you may be asking a bit much of that boat, unless you and your friend are little guys. Boats that size tend to be a bit tippy.
Tue Jul 10, 2012 11:14 pm |
waterfowl1
Joined: Sun Jul 17, 2011 12:02 pm Posts: 335 Location: hayward, wi
 Re: 12' flat bottom
you wont be movin but at a snails pace and wouldnt want to go out on the water with too much of a breeze.
_________________ Wish in one hand and shit in the other, see which one gets filled first. If yur gonna be stupid, you might as well be smart about it.
Wed Jul 11, 2012 2:40 pm |
Docott
 Re: 12' flat bottom
Had a 9hp lt on a 1430 bateau. It moved with three ~175# guys and gear. Less than 10mph I'd guess But it did move and beat the shit outta the 9hp outboard we had before which was always shearing pins on the prop. Rode pretty low, but we hunted flooded bean fields, so it didn't really matter.
_________________ Phil Robertson said,"It seems like, to me, a vagina -- as a man -- would be more desirable than a man's anus,"
Wed Jul 11, 2012 4:52 pm |
55@28
Joined: Fri Apr 13, 2012 3:01 pm Posts: 238 Location: Eagle River, Alaska
 Re: 12' flat bottom
Why not get a little copperhead surface drive, their little motors seem to work well.
Wed Jul 11, 2012 6:41 pm |
Docott
 Re: 12' flat bottom
There's a review by a guy with a 14xx duracraft w a 12hp ch on here somewhere.
Wed Jul 11, 2012 7:04 pm |
lilurb_03
 Re: 12' flat bottom
Well, I acquired this motor for free along with the boat. Thats kinda why I'm sticking with it, also the warden a.k.a my wife thinks I should do this instead of buying a boat setup already right now. Anyway we are jus gonna use it to go up and down river hopefully, and maybe go to the lake every once and awhile during season. I found some hope up parts on the web and I think we'll do that and try and get around 3-4 more horse out of it. Both of us way 160-190 a piece, any more thoughts are much appreciated and are always considered. Thanks for all the responses!!!!!
Wed Jul 11, 2012 9:20 pm |
mud slinger 69
Joined: Sun Aug 28, 2011 4:27 pm Posts: 1194 Location: Utah
 Re: 12' flat bottom
It will push it.Weight is going to be the problem.Wont be no speed demon buy should work.My 1st boat with a longtail did 6mph.Beat the shit out of walking.
_________________ We ant just mormons and polyganists we got rednecks too
Thu Jul 12, 2012 8:41 am |
waterfowl1
 Re: 12' flat bottom
or swimming!!!
Thu Jul 12, 2012 3:20 pm |
MaXXis85
 Re: 12' flat bottom
Sounds like you will be swimming. 2 guys and a dog in a 12x36..... not too stable. If you cough you might capsize.
Thu Jul 12, 2012 3:23 pm |
Docott
 Re: 12' flat bottom
Only one way to find out
Thu Jul 12, 2012 3:32 pm |
Docott
 Re: 12' flat bottom
Put a deck on the front and weld on side extensions to keep the water out, or put a top on it like the phowler prowler sneakboats. That way if water gets over the sides/bow it still won't be able to get in the boat.
Thu Jul 12, 2012 3:33 pm |
waterfowl1
 Re: 12' flat bottom
or just get a bigger boat...
Fri Jul 13, 2012 7:57 am |
Docott
 Re: 12' flat bottom
Then there's that
Fri Jul 13, 2012 8:02 am |
lilurb_03
 Re: 12' flat bottom
Thanks guys for all the help! I think I'm gonna try it cause like you guys said only one way to really know!  And if the long tail I build works out, I got a trick up my sleeve.
Fri Jul 13, 2012 9:18 pm |
