It is currently Wed Jul 16, 2025 9:57 am
Reply to topic  [ 10 posts ]
 can you put pods on your boat with a surface drive?
Post can you put pods on your boat with a surface drive?
i have a 16 36 and my motor is weighing my back end down. wanting to know if you can put pods on with a surface drive hanging off the transom.
Tue Jul 10, 2012 12:01 pm
Ya. Don't work the best though. If mounted at the surface they will disrupt water flow. I had em on my previous boat. It did not affect the SD at all but I had em mounted an inch above the bottom of the transom so when on plane they wouldn't touch the water. You do loose some buoyancy when mounted that way though.
Wildberry "Between You, Will, DUCK HEARSE, and PODCAST I have trouble reading anything on here"
23GTR stage 2 by Calen pushin a 1746 Kliebert
Tue Jul 10, 2012 12:08 pm
Post Re: can you put pods on your boat with a surface drive?
No, you cant do it.
what motor do you have?
Wed Jul 11, 2012 7:20 pm
^^ That's a false statement. You CAN do it. You shouldn't do it is a bit more accurate.
Is yer boat ass heavy er somethin? Why do ya feel the need fer pods?
Wed Jul 11, 2012 7:35 pm
Wed Jul 11, 2012 8:37 pm
Am I the only other one that saw what size his boat is??? 16/36, so no pods are NOT an option for him, because they'd have to be like 6-8" wide at most.
Honestly, your best bang would be selling it & buying a lil bigger boat (either go longer or wider)
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Jul 11, 2012 9:00 pm
Wow. Ya agreed. No way on that boat. Thanks fer pointin out the obvious TC.
Thu Jul 12, 2012 6:03 am
Somebody knows a North Louisiana Redneck an appoligy.
Thu Jul 12, 2012 9:53 am
Why no pods on the 36 inch bottom I have seen it multiple times
Sat Jul 14, 2012 9:57 pm
An outboard doesn't weigh as much as a mud motor, so an 8" wide pod will float it better. It wouldn't have enough bouyancy to have much positive effect for a mud motor, but would yield considerable negative effect because of the water disruption.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Jul 14, 2012 10:29 pm
Users browsing this forum: Majestic-12 [Bot] and 90 guests
