It is currently Thu Jul 17, 2025 6:59 am
Reply to topic  [ 5 posts ]
 7 hp Kohler throttle jumping
Post 7 hp Kohler throttle jumping
I have a 7 hp kohler copperhead mud motor. I noticed that sometimes when I rev the motor up to max the throttle jumps back and forth to a lower RPM. It is not just the throttle cable because I tried holding the actual throttle on the engine and it still did it. I can see the spring and something that revs the motor physically moving back and forth--I am mechanically challenged when it comes to motors if you can't tell--. Through the search I found someone replaced one of the small springs and it replaced the problem. Also, through google searches I found it could possibly be it needs a carb clean. Either of these sound correct? Thanks.
Tue Jul 24, 2012 9:16 pm
Post Re: 7 hp Kohler throttle jumping
sounds like ur governor kicking in and out. try a stiffer gov spring. but watch ur rpms.
JUST ANOTHER FARMER ON WELFARE
Tue Jul 24, 2012 9:22 pm
Will do. Guess I need to invest in some sort of tach.
Wed Jul 25, 2012 10:15 am
hes right. its your govener spring. its only doing that cause you are reving it up with no load on it. put it on a boat and in the water and it will not do that. the govener is doing that for a reason to prevent you from over reving it and blowin it up.
Wish in one hand and shit in the other, see which one gets filled first.
If yur gonna be stupid, you might as well be smart about it.
Wed Jul 25, 2012 8:53 pm
It did it a few times while on the water the other day too, but when I think about it, it was probably when I was digging out of mud or when my motor flared up out of the water. You are probably right. Thanks for the help, I'll run it a few more times and pay closer attention to it next time before I start messing with anything.
Thu Jul 26, 2012 6:09 am
Users browsing this forum: No registered users and 92 guests
