Mudd, here comes Da Muttmotor! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=3101 |
Author: | 50fps [ Fri Jul 10, 2009 1:19 pm ] |
Post subject: | Mudd, here comes Da Muttmotor! |
First let me say thanks to the guys at EVT for modifiying their manifold for me. Also I'd like to say thanks to Mudd for finish/adjustment work on the flanges, I got it bolted on and running this morning. Got some fine tuning to do and going to build a hard linkage setup so as to retain the original PD style throttle. S&S, EVTand PD. 001.jpg S&S, EVTand PD. 004.jpg S&S, EVTand PD. 003.jpg |
Author: | deadbird8 [ Fri Jul 10, 2009 1:38 pm ] |
Post subject: | Re: Mudd, here comes Da Muttmotor! |
Very nice! Benefits of the S&S over the HSR? (just curious) |
Author: | 50fps [ Fri Jul 10, 2009 2:00 pm ] |
Author: | bayouboy [ Fri Jul 10, 2009 8:54 pm ] |
Looks Good Myboy! Sure wish you lived closer, I would like to give you a hand with that throttle! Are you still running off the governor? |
Author: | 50fps [ Sat Jul 11, 2009 6:31 am ] |
Author: | balloon-knot [ Sat Jul 11, 2009 9:07 am ] |
It has to be good if it comes from Viola, WI!! ![]() ![]() What model and size? I got a few mid to late 80's S&S carbs laying around/ |
Author: | 50fps [ Sat Jul 11, 2009 10:10 am ] |
Author: | Rail [ Sat Jul 11, 2009 6:01 pm ] |
replied to your pm.. I hope I'm wrong.. ![]() |
Author: | mudd [ Sun Jul 12, 2009 1:03 pm ] |
Excellent Ill get into the linkage parts I have here and see what we can do. |
Author: | sea-n-spots [ Wed Jul 15, 2009 7:01 pm ] |
Looks good; if I could ask, what are the angles sandwiched around the support brackets of the BPS for? I'm curious due to the fact that I'm having some issues with mine. |
Author: | Pooh Bear [ Wed Jul 15, 2009 7:15 pm ] |
Looks awesome........Might have to take the S & S off the sporty and in stall it on the mud motor. What kinda rigging on the exhaust did you do? |
Author: | 50fps [ Wed Jul 15, 2009 7:20 pm ] |
Author: | sea-n-spots [ Wed Jul 15, 2009 7:39 pm ] |
Can you elaberate a bit. I cracked mine on one of hte tig welds on the left head flange, along with the left support bracket @ the 90 degree bend. I'm guessing that the angles are connected to the alum. plate just below the clutch for added support ? |
Author: | 50fps [ Wed Jul 15, 2009 7:56 pm ] |
Author: | sea-n-spots [ Wed Jul 15, 2009 8:12 pm ] |
Thanks for your help, I was wondering is I was the only misfortunate one; glad that there is a sight like MMT and for good mudders like yourselfto share data. I thought of tig welding some small gussets in the middle of the bracket bends, and simply v out the crack and tig up. But did not want to void any warranty. If I hearing you correctly BPS will probally ship the brackets to up-grade the supporting of the new exhaust assembly. Again thanks............. |
