Tanner Wildes
 Having problems Need Help!!!
Hey guys, I have a Mud Buddy 35 HD, I just put two new BPS heads and mikuni carb on it. Followed the directions to a T. my motor now will not idle, I have to pull on the throttle just to get it to run, I have tried tighting the throttle cable, with no luck. But the main problem is there is gas coming out of the Carb through the air intake everytime I pull on the throttle. Does anybody have any idea why this is happening, and what I can do to fix it?
Thanks, Tanner Wildes
_________________ Tanner Wildes www.wisconsinwaterfowler.com
Wed Jul 25, 2012 7:40 pm |
Team Camo
 Re: Having problems Need Help!!!
The accelerator pump "nozzle" or "jet" is facing the wrong way. It should be spraying into the carb when you give it throttle
Wed Jul 25, 2012 8:34 pm |
vertical_edge_800
Joined: Thu Dec 30, 2010 5:48 am Posts: 274 Location: Palmer, Alaska
Thu Jul 26, 2012 4:40 am |
Tanner Wildes
yeah thats what I thought too, but it is facing into the carb, its like a cloud of gas coming out if it, not a stream of it.
Thanks, Tanner
Thu Jul 26, 2012 4:43 am |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
is it back firing through the carb? Need lil bit more details
Thu Jul 26, 2012 6:10 am |
Tanner Wildes
Yes it is, the jet is shooting into the carb, not out. It's like a cloud of gas coming out. The engine only runs when I'm on the throttle, it won't run otherwise. And that is when the gas is coming out of the air intake.
Thanks, Tanner
Thu Jul 26, 2012 7:20 am |
take'emgator
THe mist you see is the back firing through the carb while the accelerator pump is squirting at the same time making the mist, A carb will backfire under either a lean condition, or a malfunctioning accelerator pump. which to fix this you may need to make a little adjustment. If that don't fix it look for a vaccum leak. With new ported heads you created more air flow therefore you may need to increase fuel, air fuel mixture has got to be right
Thu Jul 26, 2012 7:46 am |
waterfowl1
Joined: Sun Jul 17, 2011 12:02 pm Posts: 335 Location: hayward, wi
sounds maybe like its pulling air from somewhere other then the carb. except for when you are on the throttle and its pulling hard enough to pull the air and the fuel from the carb. got a good seal from carb to manifold?
_________________ Wish in one hand and shit in the other, see which one gets filled first. If yur gonna be stupid, you might as well be smart about it.
Thu Jul 26, 2012 7:51 am |
Will
The bolts that came with my intake adapter were about two threads too long and bottomed out just about the time the adapter got snug. After a few runs mine started acting up and wouldn't idle, turns the gasket between the adapter and the intake got sucked in. I went to Ace and got some bolts 3/16th shorter and a new gasket and good to go.
May not be the problem but worth checking... take the the gasket out and put the bolts back in to make sure they are seating enough.
Thu Jul 26, 2012 8:26 am |
take'emgator
I'm willing to bet you have an intake leak, leaning out the motor and causeing you back firing through the carb. Check and make sure all gaskets on itake said are tight and in good shape. You don't won't to run lean cause you'll end up burning up a piston.
To lean it'll back fire through the carb To rich it'll back fire through exhaust
Thu Jul 26, 2012 9:27 am |
Kja0792
Same thing mine is doing going get a mikuni hopefully tgat will solve my problems
Thu Jul 26, 2012 11:04 am |
richard nagon
A flat cam will also cause a pop back thru the carb
_________________ JUST ANOTHER FARMER ON WELFARE
Thu Jul 26, 2012 11:25 am |
Kja0792
I hope my aint flat i aint got an hour on my motor yet brand new cam at build
Thu Jul 26, 2012 12:32 pm |
take'emgator
The motor would be making some noise if the cam was flat, you would have some other tattle tails also. More than likely your carb just needs some adjustment.
If you've read some of the other threads those heads have been known to have leaky vlaves, this would cause your motor not to idle correctly, rather an erratic idle or no idle at all.
Thu Jul 26, 2012 2:23 pm |
richard nagon
did u replace the needle and seat that came with the kit. ? check for debris in the carb. also check to make sure ur pilot needle jets are not hanging up. make sure that your acc. pump linkage is fully relaxed at idle.then set ur acc pump. set ur idle mixture screw turned out two turns from seated position thats a good starting point. also check for a vacumn leak. u can use intake cleaner or propane to test for leaks. do a cylinder balance test. if u don't want to buy a tester. rig up a bushing to screw into head with a compression hose and air fitting. air up a cylinder using shop air and listen thru your intake and exhaust port for a leak. also can use soapy water to check for a gasket leak. around any mating surface as a head or intake gasket etc. every one puts out a questionable product from time to time but im heads are not as bad as some make them out to be. and yes a going flat cam will pop back thru the engine. disrupting the intake and exhaust cycles. and unlike u takem i have seen untrained techs setting valve lash on a going flat cam till they damn near run out of rocker arm adjustment. not knowing any better. with a popping sputtering gas spitting engine.
Thu Jul 26, 2012 10:39 pm |
Will
intake gasket
Fri Jul 27, 2012 3:33 am |
take'emgator
Sun Jul 29, 2012 3:06 pm |
craig
Sun Jul 29, 2012 3:45 pm |
take'emgator
On the other hand just trying to help this fella out. Back on topic.
Sun Jul 29, 2012 8:59 pm |
Tanner Wildes
Thanks for all the help guys. I broke down and had to take it to the shop to fix it, I couldn't. Looks like I had the timing off, and the valves weren't seated properly. I really screwed up. Thanks for all the help though!
Tanner Wildes
Tue Jul 31, 2012 6:19 am |
take'emgator
well whats the verdict
Fri Aug 10, 2012 9:45 am |
Will
Fri Aug 10, 2012 10:57 am |
take'emgator
dude i just got back to work, give me a break, i'll be here all weekend. lol
Fri Aug 10, 2012 11:23 am |
