It is currently Wed Jul 16, 2025 7:12 pm
[ 6 posts ] |
sftull
Joined: Tue Mar 08, 2011 1:33 pm Posts: 601 Location: Rock Hill, SC
 Engine Idle - Carb help?
Background info - 23hp home built SD w/o clutch on a 1648. It still has the stock carb!! I set the idle high (out of the water), so when I lowered the prop into the water, the boat would idle along w/o me having to give it any gas.
Problem - I have since added a clutch and I don't want to engine idling at 2000 rpm's. I took the boat out yesterday and lowered the idle to around 1200 rpm's but when I engage the clutch, the engine boggs so bad it dies. This was tested in deep water w/ the prop set at the correct height.
Motor has a cam installed and I have a 34mm mikuni on the shelf in my shop. Would the mikuni help this problem and if not what will. Buying a new motor isn't an option. I have been building this one for almost a year and I feel like I'm married to it.
_________________ 1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Thu Jul 26, 2012 5:59 am |
sftull
 Re: Engine Idle - Carb help?
So no one has every experienced this before??
New GT Rig
Thu Jul 26, 2012 1:22 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
What kind of prop you have on there? May have too much cup for your motor if its idleing at 1200rpms and then dies when you engage, have you gotten it up to speed if so what RPMS are you running at full throttle?
Thu Jul 26, 2012 2:34 pm |
take'emgator
Do you have after market exhaust? What cam is it? There could be numerous contributing factors, give me some more specs on what done to the motor
Thu Jul 26, 2012 2:36 pm |
sftull
The prop is 11x10 and it's turning about 3700 rpm's wot.
Cam came from performance v-twins....he said it was about a 280 grind. I have a 10 deg advance timing key but havent put it in yet. Stock exhaust but looking to get aftermarket soon.
New GT Rig
Thu Jul 26, 2012 7:40 pm |
sftull
Also forgot to mention, my pulley ratio is 1:1.2. 40 top and 48 bottom pulley
New GT Rig
Thu Jul 26, 2012 7:41 pm |
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 85 guests |
