gator tail trim pin
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=31080
Author:  Bayoublackhunter [ Fri Jul 27, 2012 2:21 pm ]
Post subject:  Re: gator tail trim pin
I use a 3/8 piece of all thread with a bolt on one end,
Works good,
Sent from my PG86100 using Tapatalk 2
Author:  quackconsumer [ Fri Jul 27, 2012 2:48 pm ]
Drill a hole in bolt ant put a cotter pin in
Author:  DuckHunterF250 [ Fri Jul 27, 2012 3:45 pm ]
Author:  dcboy [ Sat Jul 28, 2012 10:21 am ]
Get one from an outboard.
Author:  garrettpearce [ Sat Jul 28, 2012 10:27 am ]
Old 20 mercury trim
Author:  garrettpearce [ Sat Jul 28, 2012 10:28 am ]
Pin
Author:  Skipr [ Sat Jul 28, 2012 10:33 am ]
Author:  nocemdead [ Sat Jul 28, 2012 2:03 pm ]
If the motor has electric, manual trim why would there be a need for an adjustable pin?? The pin y'all are talking about is the resting point for the motor at the bottom of the trim cycle. Haven't , ran one of the motors yet, but I have one in Calen's shop paid in full ready to be picked up.
Author:  Skipr [ Sat Jul 28, 2012 2:29 pm ]
Author:  nocemdead [ Sat Jul 28, 2012 8:47 pm ]
Still lost.... If the pin was in the bottom position all the time would that not allow you to use the whole range of the trim.
Author:  Team Camo [ Sat Jul 28, 2012 9:22 pm ]
But then you can't trim up high enough on some boats.
Author:  ineedmud [ Sat Jul 28, 2012 9:27 pm ]
Sometimes you need to trim the engine up higher than the standard setting will allow...like when you run sand.
Author:  deltaduckmaster [ Sun Jul 29, 2012 7:51 am ]
