stage 1 vs stage 2 etc
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=31111
Author:  brianb [ Sun Jul 29, 2012 8:48 am ]
Post subject:  stage 1 vs stage 2 etc
I know this has been discussed in the past but I couldn't find it in the search
What does stage 1 upgrade vs stage 2 and 3 consist of
For instance stage 1 is what etc
Stage 2 is
Thx
Author:  autogateman [ Sun Jul 29, 2012 11:28 am ]
Post subject:  Re: stage 1 vs stage 2 etc
It depends on who builds it. Each mechanic has their own definition of 1and 2 etc.
Author:  Team Camo [ Sun Jul 29, 2012 12:42 pm ]
^^^ exactly. Calen & Hoyt stage 1 consists of cam, heads, & exhaust, SETX stage 1 is carb, heads, & exhaust.
Author:  scatters boy 316 [ Sun Jul 29, 2012 1:49 pm ]
Hoyt's stage 2 consists of his stage 1 and adding a Mikuni 42mm carb.
Author:  brianb [ Sun Jul 29, 2012 1:59 pm ]
is the heads a major factor in the performance, if i added a Cam and exhaust without the head work, would there be a huge difference or only slightly
looking for increase in low end torque and carry capacity without spending a small fortune
Author:  scatters boy 316 [ Sun Jul 29, 2012 2:13 pm ]
Hoyt's stage 1 is known for reliability and load carrying. what your running empty now is what you'll run with a decent sized load(2-3 ppl and gear) and will gain a few mph in solo speed. i think Hoyt's stage 1 costs righ around $1800.00 installed (thats heads P&P included) and in my opinion as well as many others is worth every penny.
Author:  craig [ Sun Jul 29, 2012 3:32 pm ]
Author:  brianb [ Sun Jul 29, 2012 3:47 pm ]
thanks, considering heads and exhaust first if that will be the most noticable increase
Author:  craig [ Sun Jul 29, 2012 3:50 pm ]
Author:  scatters boy 316 [ Sun Jul 29, 2012 4:46 pm ]
Author:  deadbird8 [ Sat Aug 04, 2012 5:04 am ]
Author:  tylerduckman [ Sat Aug 04, 2012 5:34 am ]
BrianB,
just remeber , a combustion engine is little more than an air pump, this is grossly over simplified but an airpump none the less. When you asked about heads, look at how they function, gas and air in to the combustion chamber - exhaust gas out. The faster and more effeciently you can do that the better, ie....bigger valve heads, more clearence more gas an air.
