It is currently Thu Jul 17, 2025 5:17 am
Reply to topic  [ 7 posts ]
 I give up lol
Post I give up lol
Ok guys I posted on here the other day about adjusting the governor. I thought it had already been done (the guy I bought it from said it was turning 4200 out of water and 3800 in water) but after getting my motor mounted and running it my "Tiny Tach" says its only running 1900-2000 rpm WOT out of water. So Im thinking of adjusting the gov. I have searched for about two hours now (internet and MMT forums) on how to adjust the governor and have found nothing. I have a 18hp Vanguard. I am pretty familiar with a wrench however small engines aren't my specialty could someone please point me in the right direction to some step by step instructions or possibly a video on how to adjust the governor?
Fri Aug 03, 2012 9:59 pm
Post Re: I give up lol
are you sure that the throttle on the handle is allowing the carb to open fully, would not think the governor would throttle it back that much
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Fri Aug 03, 2012 10:12 pm
I believe so because when its out of the water at WOT it hits like a rev limiter.
Fri Aug 03, 2012 10:15 pm
Are you sure that your tiny tach is set up right? I think I remember reading that there are different ways to set up to read the spark. I think if it is not set right, you could only be reading 1/2 of your RPMs.
Fri Aug 03, 2012 10:34 pm
Call calens engine service
Sat Aug 04, 2012 8:21 am
I believe I know wt your problem is its nothing serious on the CDI motor when you hit the high rev (or rev limiter) it throws off the Tiny Tach because the CDi box cuts off the spark for mila second to prevent over reveing. There is a screw on the throttle slide you can turn down to prevent it from hitting the high rev. I hand to readjust my GTR after putting the BPS throttle lever on.
1946 Charles Leonard Bateaux Stage 2 GTR
Wed Aug 08, 2012 10:49 pm
Go look on the mudbuddy website they have a very detailed procedure on adjusting the governor on briggs engines to get max performance
1642 custom with 35hp mudbuddy
Thu Aug 09, 2012 12:12 am
Users browsing this forum: No registered users and 91 guests
