Motor not running right...
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=31244
Author:  Barroll [ Sun Aug 05, 2012 9:23 am ]
Post subject:  Motor not running right...
So the last time I took my boat out, it did not want do idle well and it would shut off. Its a 35 with IM heads and single mikuni. It would also sputter when going from an idle to WOT. A few days later when I cranked it up it would rev up on its own to about 2200rpms, then drop back down and shut itself off. When I hit the throttle, the response is good but it doesnt drop back down in rpm's like it should, it slowly drops, then may go back up. I figured it was bad gas or a gummed up carb. So I took the carb off and cleaned out the bowl with carb cleaner and sprayed what I could from the outside. I did not take the carb completely apart. I also replaced the gas and added seafoam. After this it is still doing this. I have also tried turning the air mixture screw all the way in to 3 turns out with no help. So any help or advice would be appreciated.
Author:  MeatWagon [ Sun Aug 05, 2012 9:41 am ]
Post subject:  Re: Motor not running right...
it sounds like you have a vacuum leak somewhere
Author:  Barroll [ Sun Aug 05, 2012 9:47 am ]
Author:  cb5331 [ Sun Aug 05, 2012 10:47 am ]
Spray carb cleaner around the head/intake, intake/adapter, adapter/carb. See if it changes the way the motor runs. If it does, you have an intake leak. Those can all be symptoms of that.
Author:  OwenDickeson [ Sun Aug 05, 2012 12:12 pm ]
Turning the idle mixture screw out is just letting more air in.
Author:  MeatWagon [ Sun Aug 05, 2012 12:16 pm ]
[quote="cb5331"]Spray carb cleaner around the head/intake, intake/adapter, adapter/carb. See if it changes the way the motor runs. If it does, you have an intake leak. Those can all be symptoms of that.[/quot
it will let you know real quick
Author:  Barroll [ Sun Aug 05, 2012 1:24 pm ]
Author:  Barroll [ Sun Aug 05, 2012 1:27 pm ]
Author:  OwenDickeson [ Sun Aug 05, 2012 2:19 pm ]
That's fine. People that say theirs run best under 1 turn out have too small of a pilot jet. Per the mikuni tuning manual.
Author:  OwenDickeson [ Sun Aug 05, 2012 6:25 pm ]
Did you make any adjustments to anything before it started acting up?
Author:  Barroll [ Mon Aug 06, 2012 6:25 am ]
