gmc
Joined: Sun Jun 24, 2012 11:53 am Posts: 81 Location: DesAllemands
 cam or heads?
i have a mikuni carb and marshmellow exhaust on my 35 gtr and was wondering if the better upgrade would be heads r cam?
Sun Aug 05, 2012 7:49 pm |
cb5331
 Re: cam or heads?
Heads first.
Sun Aug 05, 2012 7:52 pm |
koonce727
Joined: Sat Dec 04, 2010 7:19 pm Posts: 106 Location: Mergens Point, WI
 Re: cam or heads?
both.... but since its only one, i would go with the heads.
_________________ Burlap Brothers
gmc
 Re: cam or heads?
im gettin 29 empty 27 with 3 ppl n dogg jus wanted sme extra hp for mud and lillies
Sun Aug 05, 2012 7:55 pm |
Podcast
Joined: Fri Dec 09, 2011 12:33 pm Posts: 1363 Location: Friggin cold up here
 cam or heads?
Heads.
_________________ Wildberry "Between You, Will, DUCK HEARSE, and PODCAST I have trouble reading anything on here" 23GTR stage 2 by Calen pushin a 1746 Kliebert
Sun Aug 05, 2012 8:00 pm |
craig
 cam or heads?
Heads
Sun Aug 05, 2012 8:34 pm |
DuckHunter251
Joined: Mon Jan 24, 2011 5:00 pm Posts: 233 Location: Milledgeville, GA
 Re: cam or heads?
Deffentley heads.
_________________ 1846 GTB with GTR 35
Sun Aug 05, 2012 8:41 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
 Re: cam or heads?
Damn.........everybody agrees on something? This can't be good!
But definitely heads first. Leaking valves are to common on the stock motors so you have to do the heads first to make sure you're not losing power there before you drop in a new cam.
Sun Aug 05, 2012 9:14 pm |
gmc
 Re: cam or heads?
yeah thats kinda what i was leaning towards wat heads u guys recomend?
Mon Aug 06, 2012 6:18 am |
dabuckmaster24
Joined: Wed Sep 16, 2009 3:15 pm Posts: 135 Location: Mineola, TX
 Re: cam or heads?
Send your heads to Cody at setx performance. He'll fix you up!!!
Sent from my C771 using Tapatalk
Mon Aug 06, 2012 7:08 am |
OwenDickeson
 cam or heads?
Cody is backed up right now with head work and receiving large volumes of calls each day. Be patient and leave a voicemail if he doesn't answer. He is an awesome guy to do business with, and will flat out take care of you.
He diagnosed a cam problem of mine over the phone. A cam that he did not sell me, or have anything to do with. I can't say enough good things about the guy.
Mon Aug 06, 2012 7:15 am |
cb5331
 Re: cam or heads?
Mon Aug 06, 2012 10:10 am |
vertical_edge_800
Joined: Thu Dec 30, 2010 5:48 am Posts: 274 Location: Palmer, Alaska
 Re: cam or heads?
Heads for sure..
Mon Aug 06, 2012 1:42 pm |
MALLARDSX2
Joined: Wed Jan 28, 2009 6:34 pm Posts: 978 Location: GA
 Re: cam or heads?
Head.....always go for head first..
Mon Aug 06, 2012 6:30 pm |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
 Re: cam or heads?
Cam
_________________ BUCK OFAMA
Tue Aug 07, 2012 7:53 am |
Docott
 Re: cam or heads?
Plugs.
_________________ Phil Robertson said,"It seems like, to me, a vagina -- as a man -- would be more desirable than a man's anus,"
Tue Aug 07, 2012 8:01 am |
Team Camo
 Re: cam or heads?
Calen also does good work. Not knocking Cody, but if he's backed up, he's backed up.
Tue Aug 07, 2012 6:46 pm |
bjg
 Re: cam or heads?
Wed Aug 08, 2012 3:20 pm |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
 Re: cam or heads?
Heck just do both, save a lil longer if that's case.
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Wed Aug 08, 2012 5:33 pm |
Team Camo
 Re: cam or heads?
Wed Aug 08, 2012 8:17 pm |
MaXXis85
 Re: cam or heads?
Thu Aug 09, 2012 6:13 am |
garrettpearce
Joined: Mon Jul 27, 2009 8:10 pm Posts: 1436 Location: down da bayou
 Re: cam or heads?
I have just the cam in an otherwise stock motor and it runs 29 with 2 people and doesn't bogg down. Nearlly as bad
Thu Aug 09, 2012 9:00 am |
huntingsmith
Joined: Sun Feb 05, 2012 7:35 am Posts: 666 Location: Lafayette
 Re: cam or heads?
Garrett what cam do u have installed? What where your speeds previously stock w same load
_________________ IT IS WHAT IT IS!
YOU BRING YOUR HOUSE DOG HUNTING?.....
Thu Aug 09, 2012 9:20 am |
gmc
 Re: cam or heads?
getting steady 28 with 2 ppl and had gas pouring out the overflow and bottom of air filter doesnt seem to correct
Thu Aug 09, 2012 11:15 am |
garrettpearce
 Re: cam or heads?
Hoyt's cam speed isn't much faster but carries a load better. def want to put heads with that cam as soon As you can
Thu Aug 09, 2012 11:40 am |
bjg
 Re: cam or heads?
Fri Aug 10, 2012 6:40 pm |
