figured out what annoying mettalic rattling noise was..
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=31293
Author:  vertical_edge_800 [ Tue Aug 07, 2012 1:34 am ]
Post subject:  figured out what annoying mettalic rattling noise was..
Turns out the brush guard for my mikuni carb was rattling against the top of the carb. Dab of RTV silicone and problem solved. That noise has been driving me nuts all summer and I couldn't figure out wtf it was. Maybe this will help spmebody else with a phantom rattling noise.
Author:  Will [ Tue Aug 07, 2012 5:12 am ]
Post subject:  Re: figured out what annoying mettalic rattling noise was..
Picture of the guard?
Author:  MALLARDSX2 [ Tue Aug 07, 2012 5:20 am ]
I have a peice of rubber glued to mine so it doesnt rattle.
Author:  mizzippi jb [ Tue Aug 07, 2012 6:43 am ]
Author:  Will [ Tue Aug 07, 2012 6:50 am ]
Follow me and youll think about a brush guard. Im waiting to snatch the carb off....
Author:  cb5331 [ Tue Aug 07, 2012 8:14 am ]
Post subject:  Re: Re: figured out what annoying mettalic rattling noise wa
Author:  CLICKSTER [ Tue Aug 07, 2012 8:24 am ]
mine was doing the same. i reached back there to bend it up and sliced the shit outta my finger. got it bent up out of the way but payed for it.
Author:  Will [ Tue Aug 07, 2012 8:43 am ]
Author:  vertical_edge_800 [ Tue Aug 07, 2012 10:33 am ]
I've knocked mine off twice, probably going to build something a with more coverage this winter. The first time I knocked it off I bent the tab where the cable hooks into the top.
Author:  OwenDickeson [ Tue Aug 07, 2012 11:01 am ]
Will,
Why not try one of Rod"s carb brackets? They're only like 40$.
Author:  Will [ Tue Aug 07, 2012 11:18 am ]
Author:  swampbilly [ Tue Aug 07, 2012 3:40 pm ]
Takemgator did a how to manual for it on a thread. Try searching thru his posts
Author:  Will [ Tue Aug 07, 2012 3:59 pm ]
Author:  OwenDickeson [ Tue Aug 07, 2012 4:26 pm ]
Remove the 2 ports in the carb that have the rubber cap. Tap them, and put an allen head set screw in them. Those ports are not needed and this should be done anyways. Those caps can rot and lean out your motor.
Author:  Will [ Tue Aug 07, 2012 5:42 pm ]
The elbows and all?
Author:  mizzippi jb [ Tue Aug 07, 2012 6:30 pm ]
I like the rain guard idea, I think Dr. Andy should add a way to support the carb a little bit and it would be the shizzle! I ended up doing the Poker1 thing. Cleaned the hell outta the mating surfaces and put rvt on it, then added a bigger clamp. Feels a lot more stable.
Author:  OwenDickeson [ Wed Aug 08, 2012 7:41 am ]
Author:  Will [ Wed Aug 08, 2012 8:44 am ]
I see it now, that's kind of what I thought but I couldn't figure out how it hooked to the adapter. I didn't think it was a hard connection between the adapter and the carb, seems like something would break with time, basically bypassing the rubber boot, right?
In case you're wondering, mine didn't come with any instructions.... ha
Author:  Team Camo [ Wed Aug 08, 2012 8:56 am ]
If it didn't have instructions, you should've let Rod know.
There's still some flex, because it's still using the rubber boot to mount to.
Author:  Will [ Wed Aug 08, 2012 9:05 am ]
I gotcha, it's resting on top of the flange of the rubber boot... I got it second hand before I knew where it actually came from and quit messing with it. I have it figured out now and will go dig it back out of the bin this weekend. Thanks for the pictures and clarifications and sorry for jacking the thread all up.
