Flywheel Puller? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=3133 |
Author: | BradS [ Sun Jul 12, 2009 1:19 pm ] |
Post subject: | Flywheel Puller? |
What size flywheel puller will I need for my 32? Will I need any other special tools to change my timing key? |
Author: | bayouboy [ Sun Jul 12, 2009 6:16 pm ] |
Post subject: | Re: Flywheel Puller? |
I'll make one for you! for 50 billion dallors! ![]() Call dem der boy dat got yer boat. and tell dem what u got planned. I'm sure dey will help you out. deys good peeples and dey have a shit load of tools to work wit! ![]() u tank me later! |
Author: | Full Throttle [ Sun Jul 12, 2009 7:16 pm ] |
You can use a steering wheel puller but a harmonic balancer puller works better b.c it mounts in 3 spots instead of 2. Run the bolts down all the way and make sure they are even or you can break a bolt. (Don't ask me how I know) Getting the nut off the crank can be difficult. I think an impact wrench works best. Socket size should be 1 1/4" or 1 1/8". That's really all you need. Good luck! |
Author: | deadbird8 [ Mon Jul 13, 2009 4:44 am ] |
I believe the flywheel bolt is metric (like the rest of the motor)- 36MM, you can get the single socket at an auto parts store (best price I found). x2 on the Harmonic Balance puller. 2 point puller didn't get the job done for mine. |
