It is currently Wed Sep 17, 2025 12:10 pm
Reply to topic  [ 4 posts ]
 Flywheel Puller?
Post Flywheel Puller?
What size flywheel puller will I need for my 32?
Will I need any other special tools to change my timing key?
Sun Jul 12, 2009 1:19 pm
Post Re: Flywheel Puller?
I'll make one for you!
for 50 billion dallors! :lol:
Call dem der boy dat got yer boat. and tell dem what u got planned. I'm sure dey will help you out. deys good peeples and dey have a shit load of tools to work wit! ;)
u tank me later!
Sun Jul 12, 2009 6:16 pm
You can use a steering wheel puller but a harmonic balancer puller works better b.c it mounts in 3 spots instead of 2. Run the bolts down all the way and make sure they are even or you can break a bolt. (Don't ask me how I know)
Getting the nut off the crank can be difficult. I think an impact wrench works best. Socket size should be 1 1/4" or 1 1/8".
That's really all you need. Good luck!
WC Custom 1854
Sun Jul 12, 2009 7:16 pm
I believe the flywheel bolt is metric (like the rest of the motor)- 36MM, you can get the single socket at an auto parts store (best price I found).
x2 on the Harmonic Balance puller. 2 point puller didn't get the job done for mine.
Mon Jul 13, 2009 4:44 am
