It is currently Sat Jul 19, 2025 8:35 am
Reply to topic  [ 26 posts ]
 cam or heads?
Post cam or heads?
i have a mikuni carb and marshmellow exhaust on my 35 gtr and was wondering if the better upgrade would be heads r cam?
Sun Aug 05, 2012 7:49 pm
Post Re: cam or heads?
Heads first.
Sun Aug 05, 2012 7:52 pm
both.... but since its only one, i would go with the heads.
Burlap Brothers
im gettin 29 empty 27 with 3 ppl n dogg jus wanted sme extra hp for mud and lillies
Sun Aug 05, 2012 7:55 pm
Post cam or heads?
Heads.
Sun Aug 05, 2012 8:00 pm
Post cam or heads?
Heads
Sun Aug 05, 2012 8:34 pm
Deffentley heads.
1846 GTB with GTR 35
Sun Aug 05, 2012 8:41 pm
Damn.........everybody agrees on something? This can't be good!
But definitely heads first. Leaking valves are to common on the stock motors so you have to do the heads first to make sure you're not losing power there before you drop in a new cam.
Sun Aug 05, 2012 9:14 pm
yeah thats kinda what i was leaning towards wat heads u guys recomend?
Mon Aug 06, 2012 6:18 am
Send your heads to Cody at setx performance. He'll fix you up!!!
Sent from my C771 using Tapatalk
Mon Aug 06, 2012 7:08 am
Post cam or heads?
Cody is backed up right now with head work and receiving large volumes of calls each day. Be patient and leave a voicemail if he doesn't answer. He is an awesome guy to do business with, and will flat out take care of you.
He diagnosed a cam problem of mine over the phone. A cam that he did not sell me, or have anything to do with. I can't say enough good things about the guy.
Mon Aug 06, 2012 7:15 am
Mon Aug 06, 2012 10:10 am
Heads for sure..
Mon Aug 06, 2012 1:42 pm
Head.....always go for head first..
Mon Aug 06, 2012 6:30 pm
Cam
BUCK OFAMA
Tue Aug 07, 2012 7:53 am
Plugs.
Tue Aug 07, 2012 8:01 am
Calen also does good work. Not knocking Cody, but if he's backed up, he's backed up.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Aug 07, 2012 6:46 pm
BUCK OFAMA
Wed Aug 08, 2012 3:20 pm
Heck just do both, save a lil longer if that's case.
Wed Aug 08, 2012 5:33 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Aug 08, 2012 8:17 pm
Thu Aug 09, 2012 6:13 am
I have just the cam in an otherwise stock motor and it runs 29 with 2 people and doesn't bogg down. Nearlly as bad
Thu Aug 09, 2012 9:00 am
Garrett what cam do u have installed? What where your speeds previously stock w same load
IT IS WHAT IT IS!
YOU BRING YOUR HOUSE DOG HUNTING?.....
Thu Aug 09, 2012 9:20 am
getting steady 28 with 2 ppl and had gas pouring out the overflow and bottom of air filter doesnt seem to correct
Thu Aug 09, 2012 11:15 am
Hoyt's cam speed isn't much faster but carries a load better. def want to put heads with that cam as soon As you can
Thu Aug 09, 2012 11:40 am
BUCK OFAMA
Fri Aug 10, 2012 6:40 pm
Users browsing this forum: Google [Bot] and 93 guests
