It is currently Fri Jul 18, 2025 4:10 am
[ 9 posts ] |
Favaloro
 Motor problems
My 36hp stock pd was running 28.6 mph solo. And 25-26 with me and two guys no gear. Now I took out my boat this morning and with two 130 pound people and me I was only running 19-20. Less Rpms and slower getting up on plane. Fuel bubble firm. Oil was a Lil low. But bad performance. Was wondering what I should start checking first. Maybe compression? What is stock compression on these motors? Or where else should I start? My motor is a 2009 with 137 hours. Thanks
_________________ Uncle J 18x51 2018 GTR 40xd Willey full build
Fri Aug 17, 2012 1:40 pm |
deltaduckmaster
 Re: Motor problems
Carb maybe!!
Fri Aug 17, 2012 1:42 pm |
Favaloro
 Re: Motor problems
Fri Aug 17, 2012 1:51 pm |
Will
 Re: Motor problems
Check the governor. Mine moved by itself.
Fri Aug 17, 2012 1:59 pm |
Favaloro
 Re: Motor problems
Out of water it runs 4250 Rpms in water today when I had a problem it was running 2950
Fri Aug 17, 2012 5:09 pm |
Migrator
Joined: Sun Apr 17, 2011 2:29 pm Posts: 3227 Location: Black River, MS
 Re: Motor problems
How long had it been sitting up? Gas breaking down can partially block jets in the carb. Low speed jet can be ok but high speed could be partially stopped up. Are all your fuel connections tight?
_________________ WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Fri Aug 17, 2012 9:34 pm |
da_quack_meister
 Re: Motor problems
If it has stock valves, then there may be a problem there. Stock valves are good for doing that, it happened to me. They get stuck or don't seat well, get rid of them.
_________________ 1854 Extreme CC w/ a 35 GTR a do everything machine!!!!
Sat Aug 18, 2012 2:04 am |
Favaloro
 Re: Motor problems
Sun Aug 19, 2012 8:46 am |
justinla
 Re: Motor problems
did you get this resolved? Mine is acting same, and was wondering what your solution was.
Thanks, Justin
Wed Sep 05, 2012 8:50 am |
[ 9 posts ] |
Users browsing this forum: No registered users and 87 guests |
