It is currently Fri Jul 18, 2025 9:27 am
[ 6 posts ] |
willtodo
Joined: Tue Jan 27, 2009 9:51 pm Posts: 142 Location: EAST TX.
 Need more RPMs
I got one of the 346cc preditor engines settin on an all aluminum frame LT i built and its runnin up to 3500rpms or so and dooing the sergin up and down thing if i try to go passed that. What do i need to do,,,, id like 4k or maybe 4200 out of water
_________________ off the streets and on the creeks 15/42 crawdad 23 swomp
Sat Sep 01, 2012 9:22 pm |
naj
Joined: Fri Jan 22, 2010 8:40 pm Posts: 1620 Location: Larose, Louisiana
 Re: Need more RPMs
I heard you can easily get those things up to 6000 or so. Go find a go cart racing forum and you should find what you are looking for.
_________________ 18' X 48" Center Console Sportsman Fab with a Yamaha F70LA 18' X 48" Center Console Sportsman Fab Dragging a 36hp ProDrive 15' X 42" Sea Arch with a 27hp ProDrive
Sat Sep 01, 2012 9:28 pm |
sho_freak11
Joined: Thu Jul 12, 2012 3:46 am Posts: 81 Location: Cedar Falls, Iowa
 Re: Need more RPMs
Try a Stronger governor spring
_________________ 1748 Phowler with a 35 CDI MB Sport with heads, single mikuni, cam, and gutted stock exhaust
Sun Sep 02, 2012 10:15 am |
willtodo
 Re: Need more RPMs
can i just disconect it?what other prpose does it have,,,i see that one end is connected to a lever that goes down into engine
Mon Sep 03, 2012 6:17 pm |
ironman_gq
 Re: Need more RPMs
you can disconnect it but you run the risk of over revving the motor. You may be able to put a coil from a new Honda on it I think most of the newer GX engines have an internal 4700rpm limiter built into the coil (are the predators clone motors?). Or you can adjust the tension on the governor spring to get the right rpm.
Tue Sep 04, 2012 2:46 pm |
willtodo
 Re: Need more RPMs
i can limit my rpms by simply ajutsing throttle linkage for right rpm in the water,,,,im runnin an 8x4 beavertail prop and not able to get up passed 3650 after cheating the governer.. if i run it up out of the water it will blow up over 5000,,,,,its 11 or 12 hp do i need a smaller prop,,,yes its a clone
Tue Sep 04, 2012 6:58 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 129 guests |
