Carb, and prop!
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=31650
Author:  brycecheramie [ Sat Aug 18, 2012 10:36 pm ]
Post subject:  Carb, and prop!
i have a 29 hp vanguard mudbuddy surface drive
im thinking about ordering the 35 hp stock carb from mudbuddy.
will the 35 hp carb fit my 29 hp van.
also, i want to order the mudbuddy big blade prop but not too sure if the engine can turn it.
any info will help.
if i can put the 35 carb on my engine, and turn the big blade prop, next thing will be exhaust!
thanks for any help!
Author:  med [ Sat Aug 18, 2012 11:40 pm ]
Post subject:  Re: Carb, and prop!
Bet the carb and prop would work. I know a few with the 31 that put on a 35 carb
Tapatalk 2
Author:  deadbird8 [ Sun Aug 19, 2012 7:07 am ]
Recommend exhaust first as a basis for being able to flow more air in/out of the motor. Also get rid of the stock muffler that can come apart into your cylinders.
Author:  T-Bubba [ Sun Aug 19, 2012 8:34 am ]
do heads/ exhaust before the carb... more fuel is pointless if you cant get more flow
Author:  brycecheramie [ Sun Aug 19, 2012 11:32 am ]
If i put the 35 carb, and the big blade, it still wouldn't do anything until I put an exhaust?
It wouldn't run like a 35 hp?
Will the 35 hp carb line up and fit like my 29 carb?
Author:  T-Bubba [ Sun Aug 19, 2012 1:13 pm ]
I don't think it a direct bolt on like the 31/32 carb
More fuel will not give you more power if you don't have more exhaust and intake flow
Author:  brycecheramie [ Sun Aug 19, 2012 1:29 pm ]
Thanks!
I think I'll order the single crossover tonight.
And the 35 carb may not bolt up the same as my 29 carb?
