Little Help Please! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=31870 |
Author: | lastchance [ Sun Aug 26, 2012 5:41 pm ] |
Post subject: | Little Help Please! |
Trying too run my engine. Getting fire fuel pump working, pulled carb off no trash in the bowl only too get it too stay running is too put my hand on the intake. 31 hp stock carb can anyone tell me where the jets t??? Trying too be ready for the storm. Thanks!!!!! |
Author: | UNCLE-J [ Sun Aug 26, 2012 6:33 pm ] |
Post subject: | Re: Little Help Please! |
Quick fix.... Duck tape intake closed.. |
Author: | lastchance [ Sun Aug 26, 2012 6:48 pm ] |
Or a lighter!!!!! ![]() |
Author: | duckduckboom [ Sun Aug 26, 2012 6:50 pm ] |
Idk but I am down here and willing to help if you need. |
Author: | lastchance [ Sun Aug 26, 2012 7:01 pm ] |
My sons friend just left to go blow it out with an air compressor at his house down the street! Only time will tell I think its old gas, cause it stays covered and sprayed with oil and only has 58 hours on it. It will be up for sale soon as I have the rest of the cash to get my new rig! |
Author: | lastchance [ Sun Aug 26, 2012 7:31 pm ] |
The valve on the bowl of the carb they have two wires on the bottom of it an they are both getting power!!! Well that didn't work |
Author: | duckduckboom [ Sun Aug 26, 2012 7:35 pm ] |
If you can't hear the solenod click when you turn the key it isn't working. I think I used a 3/8npt to elimate it once |
Author: | Team Camo [ Sun Aug 26, 2012 7:54 pm ] |
Definitely dump & replace the gas, then flush the fuel line. Wouldn't hurt to pull carb & clean it good, just make sure you put the jets back in correctly. |
Author: | lastchance [ Sun Aug 26, 2012 7:55 pm ] |
Got it......the valve on the bottom of the carb was stuck closed! Thanks for the help!!! |
Author: | lastchance [ Sun Aug 26, 2012 8:01 pm ] |
Author: | lastchance [ Sun Aug 26, 2012 8:03 pm ] |
I also took the bowl off and put carb cleaner in it and worked the valve several times!! |
