23 Hp rpm question
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=31934
Author:  alexm [ Wed Aug 29, 2012 10:03 am ]
Post subject:  23 Hp rpm question
How many rpms should a 23 b and s. have? Engine is still stock out of water I'm turning 3900 rpm. In water one person 3300-3450 rpms. Let me know what y'all got. And if I can do anything to get some more out of this little guy. Also recently after going wot for a couple miles engine bogs down a bit then drops to 3000. Ive checked for vapor lock, and negative, checked the plugs, no fouling, anything else I should look for. I'm new to this but I'm pretty good with my hands.
Author:  txmudcutter [ Wed Aug 29, 2012 10:19 am ]
Post subject:  Re: 23 Hp rpm question
Set your outta water rpms about 4250 you ought to get about 3900-4000 in water. Might have to bend the tab on the Carb a little to give ya a little more throttle
Author:  alexm [ Wed Aug 29, 2012 6:15 pm ]
Did what u said, rpm didn't pick up outta water. Put it in water and rpm was 3300 with 2 people. Rode around everything was fine, then started bogging at wot throttle after about 20 mins.
Author:  waterfowl1 [ Wed Aug 29, 2012 7:05 pm ]
check for an air leak.
Author:  Wildberry [ Wed Aug 29, 2012 7:27 pm ]
Had a similar problem and it turned out to be a blown head gasket.
Author:  alexm [ Fri Aug 31, 2012 12:35 am ]
K how do i check for an air leak? How much is a head gasket and is it easy to do your self?
Author:  cb5331 [ Fri Aug 31, 2012 10:42 am ]
Author:  alexm [ Mon Sep 03, 2012 5:27 am ]
Thanks guys I'll check it later on today.
