alexm
Joined: Wed Nov 24, 2010 5:07 am Posts: 276 Location: Miramar Fl
 23 Hp rpm question
How many rpms should a 23 b and s. have? Engine is still stock out of water I'm turning 3900 rpm. In water one person 3300-3450 rpms. Let me know what y'all got. And if I can do anything to get some more out of this little guy. Also recently after going wot for a couple miles engine bogs down a bit then drops to 3000. Ive checked for vapor lock, and negative, checked the plugs, no fouling, anything else I should look for. I'm new to this but I'm pretty good with my hands.
Wed Aug 29, 2012 10:03 am |
txmudcutter
Joined: Mon Jan 30, 2012 9:08 am Posts: 2307 Location: Nederland, TX (SETX)
 Re: 23 Hp rpm question
Set your outta water rpms about 4250 you ought to get about 3900-4000 in water. Might have to bend the tab on the Carb a little to give ya a little more throttle
Wed Aug 29, 2012 10:19 am |
alexm
Did what u said, rpm didn't pick up outta water. Put it in water and rpm was 3300 with 2 people. Rode around everything was fine, then started bogging at wot throttle after about 20 mins.
Wed Aug 29, 2012 6:15 pm |
waterfowl1
Joined: Sun Jul 17, 2011 12:02 pm Posts: 335 Location: hayward, wi
check for an air leak.
_________________ Wish in one hand and shit in the other, see which one gets filled first. If yur gonna be stupid, you might as well be smart about it.
Wed Aug 29, 2012 7:05 pm |
Wildberry
Joined: Sun Apr 22, 2012 6:17 pm Posts: 1018 Location: DA HAVEN FL,
Had a similar problem and it turned out to be a blown head gasket.
_________________ EMF 16x42, 3/16 skiff, 35 GTR Stage 0
Wed Aug 29, 2012 7:27 pm |
alexm
K how do i check for an air leak? How much is a head gasket and is it easy to do your self?
Fri Aug 31, 2012 12:35 am |
cb5331
Fri Aug 31, 2012 10:42 am |
alexm
Thanks guys I'll check it later on today.
Mon Sep 03, 2012 5:27 am |
