duckzbuckz365
Joined: Sun Oct 30, 2011 8:29 am Posts: 510 Location: minnesota
 Mud buddy black death 4500 idle question
i have noticed my motor once it is warm will idle at different rpms. I have the choke off and when i trim in the water or out of the water it will still idle at the same rpms. it idles at 800 to 900 then ill run it and slow down and it will idle at 1300 to 1400. is this normal?
_________________ MB 45 HD Phowler 1760
Wed Aug 29, 2012 3:58 pm |
marsh chicken
 Re: Mud buddy black death 4500 idle question
Mine does the same thing...I'm unsure of the answer though. Engine guru's?
Wed Aug 29, 2012 4:25 pm |
richard nagon
no. ck ur throttle cable or carb linkage for a binding condition. does the idle come back down if u blip the throttle ? if i understand u right. its not surging back and forth is it. if it is ck for vac leak
_________________ JUST ANOTHER FARMER ON WELFARE
Wed Aug 29, 2012 6:54 pm |
duckzbuckz365
if i rev it up then it will come back down somtimes
Wed Aug 29, 2012 7:45 pm |
Team Camo
I heard there's an issue with a bunch of the newer carbs doing that. Some were fixed by completely tearing em down & soaking for a couple days, & some still had to be replaced.
Thu Aug 30, 2012 3:08 am |
firegmc
My engine did this after my engine set for two months while I was moving into a new house. Cleaning the carb seemed to fix the problem.
Thu Aug 30, 2012 8:44 am |
Team Camo
 just realized it was a BD4500, I was talking about stock carbs, not Mikuni
Thu Aug 30, 2012 12:18 pm |
deadbird8
Thu Aug 30, 2012 9:00 pm |
jmarsh
Joined: Mon Jul 09, 2012 5:18 pm Posts: 251 Location: Hallsville,TX/ CADDO LAKE
it does the samething on myn ive found if you just pop your throttle lever it will idle back down
_________________ 4500 black death with a little more in it strapped to a 1848 wc custom
Fri Aug 31, 2012 11:14 pm |
