It is currently Sat Jul 19, 2025 8:28 am
Reply to topic  [ 4 posts ]
 PD hydaulic reverse and trim cylinders?
Post PD hydaulic reverse and trim cylinders?
Has anyone replaced their auto reverse or trim cylinders? Mine are rusting at the fittings, i know some of yours are doing the same. Can i only get replacements from PD, or on internet? how much do they cost?
thanks for any help
1848 Brother Breaux
36 hp Pro Drive FPR
Fri Aug 31, 2012 5:59 pm
Post Re: PD hydaulic reverse and trim cylinders?
If they're not leakin' just wire brush the rust off and repaint affected areas. Unless u just got some $$$ to piss away...Otherwise your local hydraulic shop should be able to fix 'em.
PRODRIVE 1860 CC
"Let the good times roll"
Fri Aug 31, 2012 6:34 pm
that's what I'm doing now. they aren't leaking yet, but i doubt they will make another year or two. I figured someone has a PD long enought they've had to replace them
1848 Brother Breaux
36 hp Pro Drive FPR
Fri Aug 31, 2012 6:46 pm
Just had my reverse cylinder replaced, it cost $295.00 at PD. not sure how much labor was tho cause I had other work done along with that.
pd36 fpr 1754 cc rig
Fri Aug 31, 2012 7:57 pm
Users browsing this forum: No registered users and 121 guests
