It is currently Fri Jul 18, 2025 11:38 pm
Reply to topic  [ 9 posts ]
 Mud buddy black death 4500 idle question
Post Mud buddy black death 4500 idle question
i have noticed my motor once it is warm will idle at different rpms. I have the choke off and when i trim in the water or out of the water it will still idle at the same rpms. it idles at 800 to 900 then ill run it and slow down and it will idle at 1300 to 1400. is this normal?
MB 45 HD
Phowler 1760
Wed Aug 29, 2012 3:58 pm
Post Re: Mud buddy black death 4500 idle question
Mine does the same thing...I'm unsure of the answer though. Engine guru's?
Wed Aug 29, 2012 4:25 pm
no. ck ur throttle cable or carb linkage for a binding condition. does the idle come back down if u blip the throttle ? if i understand u right. its not surging back and forth is it. if it is ck for vac leak
Wed Aug 29, 2012 6:54 pm
if i rev it up then it will come back down somtimes
MB 45 HD
Phowler 1760
Wed Aug 29, 2012 7:45 pm
I heard there's an issue with a bunch of the newer carbs doing that. Some were fixed by completely tearing em down & soaking for a couple days, & some still had to be replaced.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Aug 30, 2012 3:08 am
My engine did this after my engine set for two months while I was moving into a new house. Cleaning the carb seemed to fix the problem.
Thu Aug 30, 2012 8:44 am
:oops: just realized it was a BD4500, I was talking about stock carbs, not Mikuni
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Aug 30, 2012 12:18 pm
Thu Aug 30, 2012 9:00 pm
it does the samething on myn ive found if you just pop your throttle lever it will idle back down
4500 black death with a little more in it strapped to a 1848 wc custom
Fri Aug 31, 2012 11:14 pm
Users browsing this forum: Majestic-12 [Bot] and 112 guests
