gt trim unit http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=32006 |
Author: | jakecologne [ Sat Sep 01, 2012 8:56 pm ] |
Post subject: | gt trim unit |
I took the black cap off the of front the unit an touched two wires straight from a battery to directly to each side of the electric motor an the the hydraulic ram moves in an put but it doesn't work with the cap on. I checked an I have power to the parts in the black cap just not understanding why it won't work any help is appreciated |
Author: | duckduckboom [ Sat Sep 01, 2012 9:00 pm ] |
Post subject: | Re: gt trim unit |
English muthaphucker. do you speak it? Did you test your switch? |
Author: | jakecologne [ Sat Sep 01, 2012 9:10 pm ] |
Im testin it straight from a battery no switch involved |
Author: | Team Camo [ Sat Sep 01, 2012 9:43 pm ] |
Reset the breaker. If that doesn't fix it, check to make sure you have power to the switch & relays. If you put power straight to the pump & it moved, then the pump should be good. |
Author: | jakecologne [ Sat Sep 01, 2012 9:45 pm ] |
I just figured it out it took some fine tuning. I took the black cap off were the wires run into the unit and checked to make sure the electric motor still worked an it did I had some corrosion on the wires inside that black cap cleaned em up an it works fine now |
Author: | duckduckboom [ Sat Sep 01, 2012 9:59 pm ] |
get some di electric grease and put it on all the connections. Not the spray kind thou |
Author: | Robn1020 [ Sun Sep 02, 2012 6:57 am ] |
junk ![]() |
Author: | elebouef102 [ Sun Sep 02, 2012 10:55 am ] |
Author: | Robn1020 [ Sun Sep 02, 2012 9:20 pm ] |
Author: | jakecologne [ Mon Sep 03, 2012 5:16 pm ] |
it works by the way |
Author: | Gigafowl [ Mon Sep 03, 2012 6:42 pm ] |
I hear that in 2013 every GTR will come with a built in ohm meter - LOL ![]() |
Author: | jakecologne [ Mon Sep 03, 2012 6:46 pm ] |
how old is this dude ^^ |
Author: | take'emgator [ Mon Sep 03, 2012 6:50 pm ] |
He still drives a GD, you do the math |
Author: | jakecologne [ Mon Sep 03, 2012 6:52 pm ] |
there were freshman at my high school less childish than he is |
