It is currently Fri Jul 18, 2025 3:10 am
Reply to topic  [ 14 posts ]
 Opinions on this Mod Upgrade & reliablity
Post Opinions on this Mod Upgrade & reliablity
Just looking for opinions,
I have a MB 45 Mag with 250 hours- motor still runs strong and runs my GT Rogue b/t 32-35mph @ 4400-4600RPM empty (depending on prop and water depth) and hauls a load very well too.
My question is this; I basically traded things around and ended up with a set of IM Heads & dual Mikuni carbs for practically no costs. I plan to add these parts to my 45 mag (which would make it a MB 7000) and swap the pulleys/gears around so that with the added HP Im still only running 4400-4600 RPMS.
I would think compression is going to raise by about 10%, so I'll frequently check on crank cover bolts.
As a result, if I keep the RPMS the same, do you think I'm looking at a reliability problem by adding these mods?
Your thoughts or experience??
[Stage 2.5]
Tue Sep 04, 2012 12:50 pm
Post Re: Opinions on this Mod Upgrade & reliablity
Yes, you're looking at a reliability issue.
If its already running as good as you say, I'd leave it alone.
Tue Sep 04, 2012 1:03 pm
Are you going to a bigger boat?
Tue Sep 04, 2012 1:06 pm
[Stage 2.5]
Tue Sep 04, 2012 1:08 pm
[Stage 2.5]
Tue Sep 04, 2012 1:12 pm
Tue Sep 04, 2012 1:27 pm
[Stage 2.5]
Tue Sep 04, 2012 1:45 pm
Let me throw this out there, I've heard so many people talk about how great the 5500 MAG is, but Im pretty sure the 5500Mag & the 7000 have the same compression of 195-220, right??
[Stage 2.5]
Tue Sep 04, 2012 1:47 pm
I have alot of experience...as do several others here.
Several of us have run every setup imaginable.
Just ask..
Tue Sep 04, 2012 1:49 pm
Tue Sep 04, 2012 1:51 pm
[Stage 2.5]
Tue Sep 04, 2012 1:55 pm
Just sell the dual carb setup, and buy a single. Someone will buy it.
Tue Sep 04, 2012 3:30 pm
Tue Sep 04, 2012 3:37 pm
Tue Sep 04, 2012 3:41 pm
Users browsing this forum: No registered users and 77 guests
