It is currently Fri Jul 18, 2025 4:07 am
[ 4 posts ] |
16hp V twin Briggs Vanguard has no fire after smoke
xYouAreBoyx
Joined: Tue Sep 04, 2012 11:48 am Posts: 132 Location: Big BR
Buddy just got a boat and we were giving it the once over. (oil change, airfilter, greasing the shaft) Hooked it up to a 12v Battery to test the starter. Started just fine, like it always does, ran it for 5 or so minutes then shut it off. As soon as we shut it off it started smoking from both sides. Took the front cowling off and found a black wire running on top of the engine and behind the starter cowling. The wire was obviously burnt up (see the attached pics). I know a bit about small engines but a little confused by this one.
_________________ Gatortail Extreme 1854 w/ GTR 37 efi or 90hp Yamaha Godevil 1860 w/ gd 35 sd with a Mikuni Carb Sold
Tue Sep 04, 2012 11:59 am |
ŁukeŁeBlanc
 Re: 16hp V twin Briggs Vanguard has no fire after smoke
I think it's for the coil? Not positive just hooked up a kill switch on my 35 and the black wire was the coil wire just a guess
Tue Sep 04, 2012 12:11 pm |
xYouAreBoyx
After looking around google a little bit more I think that may be it. Any ideas of what could have caused it to short? The magnetos are pretty rusty but we are planning on cleaning them before we take it out. Is that engine able to use 12v without burning it up?
Tue Sep 04, 2012 4:43 pm |
ŁukeŁeBlanc
It should, I wouldn't see why not. If I had to guess I'd say over time the rubber coating wore off and caused it too short out. Just from vibration and not being properly secured. I'd just get some wire about the same size preferably a little bigger and hook it back up.
Tue Sep 04, 2012 6:13 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 86 guests |
