It is currently Fri Jul 18, 2025 10:56 pm
Reply to topic  [ 20 posts ]
 PD RPM's
Post PD RPM's
How do i turn up my rpm's? I am only running 5500-5600 in the water and 5800-5900 out of the water on a stock 36PD.
Wed Aug 22, 2012 8:45 pm
Post Re: PD RPM's
Just start turning different screws. You should be around 6000 in the water atleast.
Wed Aug 22, 2012 8:53 pm
Post Re: PD RPM's
Post Re: PD RPM's
:lol:
Tapatalk 2
1850 & 36pd
Wed Aug 22, 2012 8:54 pm
Post Re: PD RPM's
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Wed Aug 22, 2012 9:12 pm
Post Re: PD RPM's
Are you running in the low 40's?
Wed Aug 22, 2012 9:21 pm
Post Re: PD RPM's
haha took me a minute to figure out why yall were ragin me! i meant 3500-3600 in water and 3800-3900 out of water. my bad! lol
Wed Aug 22, 2012 10:31 pm
Post Re: PD RPM's
Go to the back of your motor and on the right side there will be a screw with a spring around it. That will get your oow rpms up.
Tapatalk 2
1850 & 36pd
Wed Aug 22, 2012 11:50 pm
Post Re: PD RPM's
Thu Aug 23, 2012 8:44 am
Post Re: PD RPM's
alright i did all of that, i tightened that screw that med told me to and even with it all the way tight as far as it can go it's only reaching about 4150 out of water. idle is set at 1200.
Thu Aug 23, 2012 9:52 am
Post Re: PD RPM's
Leakdown and compression check
Thu Aug 23, 2012 10:01 am
Post Re: PD RPM's
leakdown?
Thu Aug 23, 2012 10:15 am
Post Re: PD RPM's
Leakdown? Compression test? With no load? Even if it was leaking it should hit the limit out of the water...
Check to make sure your throttle is opening the carb all the way!
Thu Aug 23, 2012 10:36 am
Post Re: PD RPM's
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Aug 23, 2012 10:41 am
Post Re: PD RPM's
Thu Aug 23, 2012 10:47 am
Post Re: PD RPM's
alright thanks guys for all the info!
Thu Aug 23, 2012 8:40 pm
Post Re: PD RPM's
Sat Aug 25, 2012 4:24 am
Post Re: PD RPM's
Sat Aug 25, 2012 8:28 am
Post Re: PD RPM's
Dose any one have a pic of where that spring is located so I can see if mine is brown thnxs
Fred the Welder
Building them one at a time
Sun Sep 02, 2012 1:40 pm
Post Re: PD RPM's
I think this is the one they are talking about...looking at the back of the motor, above the exhaust shield.
Tue Sep 04, 2012 5:18 pm
Users browsing this forum: Google [Bot] and 132 guests
