Opinions on this Mod Upgrade & reliablity http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=32066 |
Author: | dadazzsaleen [ Tue Sep 04, 2012 12:50 pm ] |
Post subject: | Opinions on this Mod Upgrade & reliablity |
Just looking for opinions, I have a MB 45 Mag with 250 hours- motor still runs strong and runs my GT Rogue b/t 32-35mph @ 4400-4600RPM empty (depending on prop and water depth) and hauls a load very well too. My question is this; I basically traded things around and ended up with a set of IM Heads & dual Mikuni carbs for practically no costs. I plan to add these parts to my 45 mag (which would make it a MB 7000) and swap the pulleys/gears around so that with the added HP Im still only running 4400-4600 RPMS. I would think compression is going to raise by about 10%, so I'll frequently check on crank cover bolts. As a result, if I keep the RPMS the same, do you think I'm looking at a reliability problem by adding these mods? Your thoughts or experience?? |
Author: | craig [ Tue Sep 04, 2012 1:03 pm ] |
Post subject: | Re: Opinions on this Mod Upgrade & reliablity |
Yes, you're looking at a reliability issue. If its already running as good as you say, I'd leave it alone. |
Author: | 270Handiman [ Tue Sep 04, 2012 1:06 pm ] |
Are you going to a bigger boat? |
Author: | dadazzsaleen [ Tue Sep 04, 2012 1:08 pm ] |
Author: | dadazzsaleen [ Tue Sep 04, 2012 1:12 pm ] |
Author: | craig [ Tue Sep 04, 2012 1:27 pm ] |
Author: | dadazzsaleen [ Tue Sep 04, 2012 1:45 pm ] |
Author: | dadazzsaleen [ Tue Sep 04, 2012 1:47 pm ] |
Let me throw this out there, I've heard so many people talk about how great the 5500 MAG is, but Im pretty sure the 5500Mag & the 7000 have the same compression of 195-220, right?? |
Author: | craig [ Tue Sep 04, 2012 1:49 pm ] |
I have alot of experience...as do several others here. Several of us have run every setup imaginable. Just ask.. |
Author: | craig [ Tue Sep 04, 2012 1:51 pm ] |
Author: | dadazzsaleen [ Tue Sep 04, 2012 1:55 pm ] |
Author: | OwenDickeson [ Tue Sep 04, 2012 3:30 pm ] |
Just sell the dual carb setup, and buy a single. Someone will buy it. |
Author: | craig [ Tue Sep 04, 2012 3:37 pm ] |
Author: | craig [ Tue Sep 04, 2012 3:41 pm ] |
